Team Magic G4RS 2009
#784
Guys,
Remember me asking here about understeering problems I've been having? Well here's what happened yesterday. I tried changing my diff oils from OFNA 120,000wt front / TM 50,000 rear to TM 50,000 front and TM 30,000 rear, without changing anything else. The car immediately became, um, more free. Before the change it was struggling to change directions; now it was easy to rotate the car. The only thing was that the rear end became a little too loose so I had to lower the rear roll center and change shock positions to compensate.
I also changed the tires from 37/40 to 35/37 and the car became much more glued to the track .
I wasn't able to experiment with shock oils and such because of time but there's still a month of racing left for this season so we'll see .
#785
Guys,
i would rather experiment with the weight transfer of the car... soft diffs for me are only for low grip conditions....
in your case, i would try 60k rear diff with maybe higher roll center rear or softer front sus depending on which part of the corner you are understeering...
#786
Just Want to ask if there is a G4RS 2008? Or it is only in 2009?
#787
Trader Rating: 26 (100%+)
#788
#789
#790
using rear offset wheels
Hi team
for those wanting to use offset wheels on the back then you should look at buying the kfactory rear adjustable hinge pin mount - k14200
http://www.kfactoryracing.com/produc...4200&pageNum=1
This option also allows for more roll centre positions by moving the arms pivot point closer to the centre of the car and also helps if you are hit up the rear
#791
Gearing Combo
Any started playing around with the different gear combos yet,i have the MMRB M3 ,i want get some feedback on this combo i want to try,16/64,22/56 if im not mistake this will give ,insane bottom end power.Our Homestead track is more of you need more out of the corner,an infield power.Thanks guys feedback needed.
#792
#793
#795
Homestead Race 1
Had some bad luck this weekend,but all in all the setup was perfect ,an with the Murnan RBM3 car very,very fast.First off i want to thank my sponsors Machinaria,MurnanM,Twistertires,thank you very much .Here is my setup.
Track Condition
Surface-Med
Size-Open
Traction-Med
Front Sus
Track W-197
Anti Rollbar-0
Solid Axle
Toe -1.5 L&R
Camber 2 L&R
Ride Height-5mm
Droop-2mm
Caster-3mm
Tire-Twister 37 Shore
Dia-59.5 L&R
Shocks
Oil-500 Kyosho
Piston 2hole 1.1
Spring-Kit
Ackermann-D
Engine
Gear Ratio-16/62-22/56
MM RB M3
Rear Sus
Track W-199
Anti-Roll Bar-2.2
Diff-80,000
Toe-2.5 L/R
Camber 4.0L-3.5R
Ride Height -5.5mm
Droop-4mm
Tires -Twister 37 Shore
Size -61.5
Shocks
Oil-500 Kyosho
Piston -2hole 1.1
Spring-Kit
This was my main setup ,the only change was tire combo.
37LF
37RF
40LR
37RR
Track Condition
Surface-Med
Size-Open
Traction-Med
Front Sus
Track W-197
Anti Rollbar-0
Solid Axle
Toe -1.5 L&R
Camber 2 L&R
Ride Height-5mm
Droop-2mm
Caster-3mm
Dia-59.5 L&R
Shocks
Oil-500 Kyosho
Piston 2hole 1.1
Spring-Kit
Ackermann-D
Engine
MM RB M3
Rear Sus
Track W-199
Anti-Roll Bar-2.2
Diff-80,000
Toe-2.5 L/R
Camber 4.0L-3.5R
Ride Height -5.5mm
Droop-4mm
Size -61.5
Shocks
Oil-500 Kyosho
Piston -2hole 1.1
Spring-Kit
37LF
37RF
40LR
37RR
