Team Magic G4RS 2009 >
Like Tree3Likes
Old 07-30-2009, 05:55 AM
  #511
aizenbelle's Avatar
Originally Posted by crius
Hello!
It is my first nitro car.
What servos is better for using on the chassis?
Please recommend me good engine 0.12
I run nova's and STS they both are good brands. Also look for RB engines
aizenbelle is offline
Old 07-30-2009, 12:03 PM
  #512
Hello!
What aizenbelle mentioned on the engines.
As for servos, there are a lot out there in the market.
Many run the Futaba BLS451
Pretty sure you can get those in Moscow, or if you can try the www.savoxservos.nl
sebtarta is offline
Old 07-30-2009, 02:57 PM
  #513
Sp Racer's Avatar
Very informative write up....
http://www.teammagic.com.tw/en/newsf...29171321-20409
"The temperature is extremely high during the series and it will cause the traction too high, so the drivers have to adjust proper setting in order to prevent capsize"
CAPSZISE ! LOL!
Like i said....
Sp Racer is offline
Old 07-30-2009, 04:14 PM
  #514
Trader Rating: 26 (100%+)
Questions??
has anyone had this problem with there clutch rubbing the 2 speed housing my car was running ok but then it just stop then i seen that the two parts were rubbing and my clutch shoe melted i took the clutch apart and i think it was because of the shims i had behind the bearing but now i need a new clutch shoe to find out. i love the car i hope you guys can help me out thanks
RANDY SMOOTH is offline
Old 07-30-2009, 06:01 PM
  #515
MACHINARIA's Avatar
make sure that this two parts are not rubbing when setting the mesh. we like to add our shims at the Thrust Bearing Retainer.
Best regards
www.machinaria.com
MACHINARIA is offline
Old 07-30-2009, 06:35 PM
  #516
Best regards
www.machinaria.com
thanks, you guys are the best
Old 07-31-2009, 02:13 AM
  #517
gtrmx's Avatar
Let's see if I am understanding your problem. I am sorry if my following words result unnecessary as you may already know this, but that would only reflect my lack of understading of your question.
I am going to assume that you have already set your clutchbell clearance somewhere between .4 to .7mm, per the instructions.
Once you have that set, then remove the clutch bell again and place enough shims between the clutch spring nut and the first bearing (the one closer to the engine's case) so that the bell is spaced out and still allows the thrust bearing to move freely.
After tightening down the clutch bell against the engine, there should now be a .1 mm gap in which the bell will move freely without touching the shoe.
Now the engine will not make the clutch engage until the revs are high enough, just like usual, but the bell will not overheat the shoe.
Typically, instructions will always tell you to add shims on the outside of the bearing retainer but will hardly ever tell you to remove the bell and bearings again to add some more shims inside...
Please let me know if this is what you are asking for. If I am wrong then I would like to try the other thing I am thinking about to be your problem.
gtrmx is offline
Old 07-31-2009, 02:43 AM
  #518
Sp Racer's Avatar
I think he is referring to the clutch bell touching the 2nd gear housing..
Sp Racer is offline
Old 07-31-2009, 04:32 AM
  #519
that is it . i got it working. thanks you guys are the best
Old 07-31-2009, 08:01 AM
  #520
aizenbelle's Avatar
that is good! I forgot to mentioned that when I first build my car
Old 07-31-2009, 11:43 AM
  #521
getpip's Avatar
CAPSZISE ! LOL!
Like i said....
I capsize regularly!!!
getpip is offline
Old 07-31-2009, 12:09 PM
  #522
aizenbelle's Avatar
I do it on a regular basis too
Old 07-31-2009, 12:11 PM
  #523
aizenbelle's Avatar
Can anyone post a pic of how much Dario shaved the top carbon plate? thank you in advance
Old 07-31-2009, 02:21 PM
  #524
gtrmx's Avatar
Thanks for the clarification!!
gtrmx is offline
Old 07-31-2009, 04:30 PM
  #525
MACHINARIA's Avatar
Default Kfactory upgrades
K Factory upgrades.
visit the G4RS 2009 page for a weekend special!!!
