Serpent 733 1/10 200mm touring >
Old 08-03-2009, 09:51 AM
  #721
clmbia45's Avatar
Originally Posted by dj apolaro
Gonzo
I think once you get the longer springs the 6mm of ride height will work. Unless the track is real bumpy. Then maybe 6.5mm.
I am using 40wt serpent oil and about 25% rebound. Also just for your info 40wt serpent is 1,000cst in other brands.
Good luck and keep us posted and we can offer help if you still need.
DJ Apolaro
I tried a set of long yellow springs yesterday with fair/good traction, 80,000 front, 30,000 rear) (rest of set up per DJ). Rear end was stuck, with a slight push in high speed turn. 42 front and rear. Temp 108 degrees.
clmbia45 is offline
Old 08-03-2009, 10:54 AM
  #722
clmbia45's Avatar
Inspection car weight, with JR servos, NMHI batt., Stratus 3.1, Spectrum with temp telemetry: 1863 Gm. Lipos just ordered!
clmbia45 is offline
Old 08-03-2009, 12:11 PM
  #723
Gonzo RR's Avatar
Yep, I had the nut way to loose. That must had been the reason why I didn't have enough take off power. hmmm! I should have known that one.
I'm sure the 40wt oil will make a difference. I will make small adjustments first so that I can tell more accurately what was it that needed to be changed on the set up.
MCSMOOTH: I do race at LEISURE HOURS RACEWAY home of the 2009 ROAR NITRO OFFROAD Nationals. Is a good 50min drive from where I stay, but its well worth it. Man, you don't know how sad I am because I might not be able to do the Byron challenge I know I can at least make it to the A main on the GT class and get some $$$$
I will do my best to at least attend on Sunday maybe I can run a qualifier or two. I will let you know if I end up going so we can help each other out, maybe I'll have the spares for the 733 by then. Just in case...
Gonzo RR is offline
Old 08-03-2009, 06:17 PM
  #724
anyone know when the solid's and one-way coming out ?
i0kr1sol is offline
Old 08-03-2009, 07:05 PM
  #725
Gonzo RR's Avatar
Ashford Hobby has them on their website SER804184 Axle front with oneways set $45.99 and SER804185 Axle Front Solid 733 $24.99
Gonzo RR is offline
Old 08-03-2009, 10:21 PM
  #726
thanks !
i0kr1sol is offline
Old 08-04-2009, 02:15 AM
  #727
shawn01's Avatar
what brand long/short springs are you guys using on the 733, and where can I order them from
shawn01 is offline
Old 08-04-2009, 02:30 AM
  #728
you can try the stock for front but i kind the feel of an xray front...
as for the rear i cant do without the mugen longs...
katze is offline
Old 08-04-2009, 03:34 AM
  #729
quietstorm76's Avatar
Ok the long rear springs really does feel better. The car feels more planted and I didn't lose any steering. Like someone posted above I tried the old yellow as I don't have any of the new long springs but I ended up using the old red. Here is my current setup medium traction. Stratus 3.1 center post 31mm from windshield.
40's all around or 42 rear is working for me
Front:
Copied DJ's setup
Rear:
200mm track width
Long red springs 3rd hole on tower
serpent 40 oil (1000cst) 3 holes
3 camber/ 2 toe in
lower hinge pin top position
link mid inside/ inside on upright
2.3 sway bar
quietstorm76 is offline
Old 08-04-2009, 03:55 AM
  #730
Serpent has long springs for the rear. They work good. I think the key colors for the rear with be Orange, Red and Pink.
DJ Apolaro
dj apolaro is offline
Old 08-04-2009, 05:47 AM
  #731
~McSmooth~'s Avatar
Here's my GLC Setup:
Front
100K diff oil
0 droop
middle roll center position
car long
3mm caster in front of arm
5.5mm ride height
blue spring layed down
2 hole piston
40wt oil (1000 cst)
Zero toe out
1.5 camber
stock sway bar
ackermann in back position and wide
Rear
40k diff oil
2 droop
lowest roll center position on bottom pins
car long
camber link inner and 2nd position from bottom
2mm under link on outer position
6mm of ride height
long pink spring, 2nd hole up from bottom
3 hole piston
45wt oil (1400 cst)
2.5 toe in on each side
3 camber
stock sway bar
Other:
stock pinions and spurs
civic body
38 shore front, 42 rear
~McSmooth~ is offline
Old 08-04-2009, 06:13 AM
  #732
DJ Apolaro
SER160322 L27 Orange
SER160324 L27 Pink
SER160323 L27 Red
Old 08-04-2009, 06:14 AM
  #733
Gael L's Avatar
Front
100K diff oil
0 droop
car long
5.5mm ride height
2 hole piston
40wt oil (1000 cst)
Zero toe out
1.5 camber
stock sway bar
Rear
40k diff oil
2 droop
car long
6mm of ride height
3 hole piston
45wt oil (1400 cst)
3 camber
stock sway bar
Other:
civic body
Did you run the wing standard with this setup or did you move it back a few mm? This setup looks like it has tons of steering.
Gael
Gael L is offline
Old 08-04-2009, 06:19 AM
  #734
Front
100K diff oil
0 droop
car long
5.5mm ride height
2 hole piston
40wt oil (1000 cst)
Zero toe out
1.5 camber
stock sway bar
Rear
40k diff oil
2 droop
car long
6mm of ride height
3 hole piston
45wt oil (1400 cst)
3 camber
stock sway bar
Other:
civic body
Your tire choice, did you run that shore gap because of understeer? I'm wondering if you noticed a lose of on power steering with the Civic compared to the Stratus?
Old 08-04-2009, 06:20 AM
  #735
Wassup Gael? How you likin' the car?
