Serpent 733 1/10 200mm touring
#2641
Living here now not sure which number you have but my email is the same .
Done with racing bikes I still ride the mountains are great here,thinking of RC-ING again though
#2642
get rid of the hpi mustang body.. Get a blitz isf or rs4.
#2643
Blitz Atlis 2.3 & Xceed Chevy Kruzer had more steering !
#2644
okay guys. i need to know if there was a running change in the gas tanks? i have 3 tanks that are clear and one that is white clear.
#2646
no i got a new motor and it sounds like a air leak it idles on the starter box once it warms up to temp it starts to idle up and down not slow either kinda rapid like say it goes from 1,000 rpms to 1300 rpms rapid.. change the tank out and the fuel line not sure what else it could be i just changed the exhaust gasket see if that would be it. and the motor wants to run hot as well.. im pretty sure i got the clutch set right so i dont think that is causing it. clutch is set with 1.2 clutch nut end play is at .38 and im not sure how to measure the air space between the clutch bell and clutch shoe but its does not rub..
#2648
I would double check your throttle linkage setup, and also richen your bottom end alittle.
#2649
okay just so i get this right i want the end play to read 0.10 and the clutch nut at 1.2 or 1.3 with a air gap at .70? or .07? sorry for questions new to the centax.
#2650
Trader Rating: 9 (91%+)
#2651
kool motor is fixed thanks guys the clutch just wasnt right my bad. i had to get the manual back out and read how to set it all i was doing it in reverse setting the air gap less and the end play more.. after i got that straight she is good to go. thanks again
#2652
My realization for resist my mistakes.
i can't post the URL for my image because i'm rookie in rctech. !!!!!
The bottom bumper is the model for serpent Lola 710 ref 808120, the top bumper is a model for serpent 720 ref 803155 and the foam is made with a dell packaging.
It takes a little work.
#2653
how many turns out do you guys set your 2 speed? the manual say 4 turns out.. is this correct for most people or do u guys go out to like 4.5 or 5 turns?
#2655
