Metal Diff gears for N-tc3
has anybody heard if the ofna LD3 metal diff gears will work in a N-tc3
.............Yup they will work . Are you considering putting a big block in your nitro TC-3?? I put a LRP .28 in my TC-3 kept blowing my diffs until I transplanted a steel diff and pinion gears from a LD-3 in my TC-3. Go to RC Universe website to get more info look under the thread call " Nasty 1/10 cars with big blocks "
Thanks. No l run on-road and if you curb them it will strip the gears. l heard that the Ld3 had some that would work. where did you get yours at and who makes them
Ofna makes the diff gears. You can get them from http://www.nitrohouse.com Go to their website and download their manual write down the part number so you have everything you need when you order. You will need front and rear diff cases, front and rear diffs, 2 pinions, 2 ofna short shafts and bearings. The ofna pinions won't fit on the short associated shafts. Study the manual before you order make out your list good luck.
thanks alot l will check it out
