Kyosho Evolva
#1321
Originally Posted by cdelong
yes- there seems to be a shortage of 7mm/3.5 blocks. The supply chain will catch up I'm sure. Luckily I found a set
Aaron or anyone else..... I just switched to the Evolva and have a few good used clutches from some buyouts I made. Not knowing exactly what clutch springs are in these clutches, how do I find out?? Measuring diameter/ number of coils??
Two look grey-ish and the other brown/red-ish. Is there a way to know by checking coil diameter, # of coils or on a spring machine?
The Longer Greyish one (10mm) is the one you want to use , it is known as the 4D spring. The shorter greyish one is what comes with the 3D kit and the redish one is used by somepeople but not often.
#1322
#1323
Originally Posted by SRAD
Well damn.....for us guys with non WCE 05 cars....where are we going to find these rear blocks? If someone knows of a shop that has them....please post here. Anyone that works at Kyosho America and reads this thread.....there might be a demand for these blocks....please get some in stock!!!
#1324
Originally Posted by Team Kamikaze
Got plenty in stock just for you
#1329
How much for a pair (7mm/3.5) shipped to 14519?
#1330
Rich,
What spring do I really need with this car? I have the reddish/brown ones (8.4mm long), some short grey ones (8.5mm) and a few long grey ones (10mm).
Thanks!
Thanks!
The second choices are the 10 mm JP Worlds spring and the 4D Kyosho spring - it's decent.
I would, also, recommend drilling out the puck to 4mm, all three holes. Brings the RPM up just a touch before the clutch engages.
#1331
Originally Posted by Rich Browne
I prefer the 9.25 JP Spring. It doesn't seem to "sag" as much - set it once and it is solid. The other springs need to cycle two or three times before they set - even then they don't seem to remain stable.
The second choice is the 4D Kyosho spring - it's decent.
#1332
All I have is the 93519 worlds type clutch spring
#1333
Is anyone having to place shims behind the collet to tighten the flywheel fully? I am using the 3D clutch and flywheel.
I had to put about 2- 3mm of shims behind the collet before it would tighten down. Is this common? It was on a new 35Plus21.
Corey
Corey
#1334
Originally Posted by Grinder
I have found that the Kyosho collet is the one to use. It is very short. The Novarossi collet does not work too good with the Kyosho flywheel. Also I have seen the flywheels get stretched from taking them on and off a lot.
Thanks Uriah.
I was just using what was in my pit box. Guess I'll have to get some Kyosho colletts.
#1335
It's a shame that one has to spend $70.00 plus to get these blocks...and then another $100.00 for the 07 update update kit...if you only have an 05. For those with an 05 WCE...the cost is less.
