Kyosho Evolva
Old 07-04-2005, 08:06 AM
  #946
SRAD's Avatar
Trader Rating: 15 (100%+)
Default Regionals.....when
Rich Browne.....
sorry about this being off the subject but I need to start making preparations. Is the RAMS hosting the Regionals and if so when? I can't seem to find anything on the ROAR website or anywhere else. Thanks and I appreciate any information.
SRAD is offline
Old 07-04-2005, 08:15 AM
  #947
KMW
KMW's Avatar
Originally Posted by SRAD
Rich Browne.....
SRAD,
All the Region 12 Championship information is now on the RAMS website. Here's the URL:
http://www.rams-rc.com/Region%2012%2...ain%20Page.htm
KMW is offline
Old 07-05-2005, 06:55 AM
  #948
duneland's Avatar
I have an Evolva for sale! Pics on web site. www.dunelandhobbies.com
Great car! This one has very little track time.
duneland is offline
Old 07-05-2005, 03:23 PM
  #949
Default Kissimme, Nitro Challenge set-up
Originally Posted by kanai2racer
Hi Rich,
Can you post the setup the team guys ran in Kissimme florida at the nitro challenge?
I have posted (at the Empire Site) Scott's set-up. Let me know if you have any questions.
Rich Browne is offline
Old 07-05-2005, 04:44 PM
  #950
kanai2racer's Avatar
thanks, I'll check it out.
kanai2racer is offline
Old 07-07-2005, 10:25 PM
  #951
Roger's Avatar
Why are you selling the evolva
Roger is offline
Old 07-07-2005, 10:47 PM
  #952
Mr. Browne,
Why doesn't Scott use droop?
NitroHead is offline
Old 07-08-2005, 07:43 AM
  #953
Default Up Travel
Originally Posted by NitroHead
Mr. Browne,
We measure up-travel. Droop and up travel accomplish the same end results. I am more comfortable measuring up travel. The majority of us (Scott Kimbrow, Rick Davis, Jim Adkins and I - 75% of Empire Racing) all ran for and were taught by Ron Paris. Ron was a classic. He did things his way - (that should make a few folks smile) - can you sense the understatement?
Old 07-08-2005, 02:57 PM
  #954
fraz's Avatar
Actually Rich, droop and downstops have incorrectly become synonymous in a lot of racer's vocabularies and I am just as guilty as the next guy. I know what you mean but the others may not.
Downstop==Point measured (in millimeters) at lowest part of arm or knuckle relative to the chassis, with the chassis being 0mm. This is typically measured with the chassis on blocks and a stepped gauge.
Droop or Up travel (what Empire team uses)==Car settled on flat board ready to race. Hold a metric ruler perpendicular to the flat board and slowly lift the chassis. Note the measurement from the settled ride height to the point where the tires lift off the board and this is your actual droop or up travel measurement.
That said, am I to understand you have the rear downstop screws backed out entirely? I can just see Ron watching this thread now laughing his ass off
fraz is offline
Old 07-08-2005, 03:47 PM
  #955
Default Upstop/Downstop - Droop
[/QUOTE]
That said, am I to understand you have the rear downstop screws backed out entirely? I can just see Ron watching this thread now laughing his ass off[/QUOTE]
John, we (Empire) don't use the front downstop at all. The Empire Sway Bar bracket doesn't even allow for that adjustment. Additionally, we don't us the rear downstop either. The upstop (rear) is used just to protect the shocks. You racing Sunday?
Old 07-08-2005, 04:57 PM
  #956
Huh? I always watched Ron measure droop on my car.
Mike_Swauger is offline
Old 07-08-2005, 05:26 PM
  #957
Default Droop
Thanks for the clarification Mike. He just showed me the old up travel.
Old 07-08-2005, 10:03 PM
  #958
mrx
mrx's Avatar
Trader Rating: 19 (100%+)
Hi to all. I just got the evolva and ran it over the past weekends and found out that the rear shocks were oily like leaking somewhere after a few tanks of run and the others that"s not leaking become (dead) no tension without spring on it and is still full of shock oil in it.I have never had this issue in mrx3 and can the mrx3 shocks use in the evolva?
mrx is offline
Old 07-08-2005, 10:06 PM
  #959
mrx
mrx's Avatar
Will the evolva have the front wide belt conversion kit available sometime?
mrx is offline
Old 07-09-2005, 04:24 PM
  #960
For the record I run no upstops (which is confusing 'cause they prevent the chassis downward movement or bottoming out)
9mm rear droop and 0mm front droop.
The car is awesome by the way...
Rich can you ask Scott what his settings are?
