Shepherd Velox V10 >
Shepherd Velox V10
Shepherd Velox V10
Old 02-13-2011, 11:18 PM
  #961
Originally Posted by jas1
DH Modelsport is the uk distributor mate, should be here in a couple of weeks, you after another car now?
yea definitely. i am not happy at all with the capricorn.
omegaf is offline
Old 02-13-2011, 11:34 PM
  #962
Fair enough, get hold of Dave at DH he will sort you out mate
jas1 is offline
Old 02-14-2011, 10:37 AM
  #963
yep, i have already found the website. I will wait until it is released and the specs are final and then early next month i will place my order.
omegaf is offline
Old 02-14-2011, 03:03 PM
  #964
Originally Posted by xr8man
first time out with the new car no real problems apart from the rear end stepping out on fast corners can anyone tell me how to stop this have tried
shock oils roll centers cambers castors running out of ideas i am running a locker in front with 80k rear diff any help would be greatful
Try fitting a blow up sheep doll to the rear of the car. This will provide additional downforce to stabilise the rear end on fast corners.
Alternatively, use the other car in the cupboard. That one was plenty stable.
Love ya D.
Team RMR is offline
Old 02-14-2011, 03:59 PM
  #965
CHRISP76's Avatar
Just out of curiosity, what is wrong with the capricorn??
CHRISP76 is offline
Old 02-14-2011, 04:24 PM
  #966
seems like i got a bit unlucky with my kit. some screws are missing, a diff shaft was faulty, the manual is an outdated version that shows inexistent parts and wrong screw sizes, some of the parts fit together quite poorly with either big gaps between them or too tight fit that need to be hammered in place.
thats all i have encountered so far and i have prepared about half the car. they got very good service though and they respond to the problems immediately so i trust everything will go well eventually.
omegaf is offline
Old 02-14-2011, 04:30 PM
  #967
xr8man's Avatar
Love ya D.
yep no worries s.b i will bring the gumboots specially for you next club day
but unfortunately this car is now more stable than the car on the shelf all issues
now solved had the body mounted to far forward which was not allowing enough rear down force so the velox has more steer and rear bite than the xray hope ya leg gets better soon mate ps come down next club day and see the car preform
cheers smuggs
xr8man is offline
Old 02-18-2011, 01:19 PM
  #968
Thumbs up
Hey Guys,
My new V10 will be here on Monday and was just wondering what tricks and tips you guys have for me during the build.
Hanging out to get it looks like a good car, Smuggler what did you do to get the rear to settle down.
I will be putting the kit setup on for starters then go from there. Hopefully be down the track with it in the next couple of weeks for testing.
Cheers,
Michael
Mike 78 is offline
Old 02-18-2011, 02:33 PM
  #969
MrSlow's Avatar
MrSlow is offline
Old 02-18-2011, 04:40 PM
  #970
xr8man's Avatar
Originally Posted by Mike 78
Hey Guys,
Cheers,
Michael
Hi Michael what i would suggest for moorebank is build it as kit set up but i would put 600sct oil in the rear shocks and 500sct in the front the problem i had was when i ran the protoform p37n body the rear end would just spin out on high speed corners not enough rear down force i re tested the car with a p56 body and the rear end was so planted and then went back to the p37 and it just kept spinning out on high speed corners and use the grey springs on the front and green on the rear
but our track here in lilydale is getting bumpy so you might not have that rear end problem there i can tell you they have awsome steer and good acceleration hey mike pm me your number so as i can have a chat to you
cheers smuggs
xr8man is offline
Old 02-18-2011, 08:51 PM
  #971
cheers smuggs
Thanks Smuggler i get the kit hopefully monday then as soon as i have built it i will be out testing. i will pm you my details. Thanks for the help.
Mike 78 is offline
Old 02-21-2011, 06:36 PM
  #972
MrSlow's Avatar
when can we buy the ELEVEN?!
MrSlow is offline
Old 02-21-2011, 06:51 PM
  #973
'11 was released yesterday. You should see it in stock in a couple of weeks max.
omegaf is offline
Old 02-23-2011, 09:05 PM
  #974
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default Steering knuckles
quick question
i got my car last season and purchased quite a few parts with the car..
and all the steering knuckles are the ones that are extremely fragile.
Any ideas on what to do with these parts.
will shepherd replace?
How do I know/tell which are the new improved version?
car was fantastic as long as I didn't tap or look at a corner the wrong way.
Any help would be appreciated.
I would like to run this car this season if at all possible.
olhipster1 is offline
Old 02-24-2011, 07:21 PM
  #975
olhipster1's Avatar
Default no help
Originally Posted by olhipster1
quick question
anyone got an answer....any factory support here on Rctech?
