Serpent 710
Re: Re: Re: Re: ATTENTION: TRACTION ROLL...Help!Help!
Originally posted by Proficar403
Your setup just looks too stiff...blue/red with 50w.
It does not make the car sluggish, that's for sure.
Originally posted by mariochi
P.S.front shock more vertical is IMPOSSIBLE WITH LOLA body and Lolashocktower.
TODAY I HAVE TRIED yellow sping all around . The car is incostant in lap time and it is , at the same time , too attached to the ground and not well predictable when you push it to the limit....
ALREADY DONE
SEE MY SETUP HERE : www.mytsn.com/setups/setup.asp?sid=2350
any GOOD IDEAS????
ALREADY DONE
any GOOD IDEAS????
I would also try softer shocks all round (yellow springs with Serpent 30wt oil with 4 or 5 holes) like what Proficar403 advised but use the sway bar to tune and harden the front end to your liking. Works for me.
Re: Need help with setup - car pushes
Originally posted by GlennCauley
THINGS I WAS THINKING OF CHANGING:
1) Front roll center - lower
2) Front caster – less
3) Front track-width - narrower (will also help with dogbone issue)
Perhaps also loosen a little on the rear ball diff helps the car rotate around the corners easier. A slightly higher rear roll center works too.
That's what I thought, until I finally tried it and got a second faster. You also get the luxury of even tire wear. No more truing just the fronts. I was actually disappointed in the car until I tried 37F/40R, now I love it!
Another change that works well is standing up the front shocks. It does very well in making the car turn in more aggressively.
Me, and some friend of mine have some trouble with traction roll with Serpent710 when the track is well gripped (AFTER 20 MINUTES OF RACE).
If I lower the front top arm holder, won't that raise my front roll center and give less front traction?
Originally posted by Pyramid
I believe Arct C has answer your question on mytsn forum. He is on of the best guy
Originally posted by GoldFinger
Bro, find yuor time to download AMCClaps by Mark Green from uncle Sow. It change my own basic rule to setup a car.
Watch carefully his car "sways"(??) into corner.
I believe he was using LB, last week I try that and my car react just like his car. Unfortunately my finger did not..
You know what, that driving style is very similar to Thai driver Suruth when I watch him drive in Thailand. Very agressive in and out of corners with the rear swaying in and out like that.
If I have the time, I'll try the LB instead this weekend to lower the rear roll center. But I think I also need to lower my front roll center to stock position to balance it out with the change in the rear.
how can I expect my s710 to handle on the track with yellow springs all around and 30wt oil basically the stock set-up Im waiting for my NovaMega
Re: Re: Re: Re: Re: ATTENTION: TRACTION ROLL...Help!Help!
Originally posted by InitialD
If you have a high speed on throttle sweeper, you need to stiffen the rear to keep the rear from bottoming out and loosing on power steering.
Once you get it running, then write down what you found lacking in the car's handling i.e. understeer, oversteer etc. Then fine tune from there.
Re: Re: Re: Re: Re: Re: ATTENTION: TRACTION ROLL...Help!Help!
Or higher ride height... if you prefer and the car has no traction roll problem
yah i need to give more ster for my 710, either i used soft front harder rear or lower tyre shore for my front
