Serpent 710
Rubber tire set up
Does anyone have a good rubber tire set up for the 710? I am going to a track out of town and they only run rubber tires.
Thanks,
Tim
Thanks,
Tim
Originally posted by Eddie M
Hey Glenn,
You should try lower the front top arm holder. That will increase the camber gain and improve traction in the corner. Take off your front roll bar! Try to use less toe in the rear too and use red sprints.
Hey Glenn,
If I lower the front top arm holder, won't that raise my front roll center and give less front traction? I am nervous about not running a front rollbar, but I guess if I made the other front roll adjustment, the front should not roll as much. Thanks, I will try all this stuff.
I was having the similar problem but I improve it by what I said above. I am running 1 degree toe-in in the rear. I also use 42 all around all day. I think this setup will work better with 40 front and 42 rear as the car still push a little more then I like. Beside, 40 42 combo will make the tires wear more even.
Thanks for the advise!
Re: Re: Need help with setup - car pushes
Originally posted by YBSLOW
If you haven't tried it yet try running your front diff really loose, but not slipping or it will push severly on throttle as well as running the rear diff a little tighter than the front will help the car rotate on small tracks. You nay also want to run a different body.
I tried a saleen at a non sactioned race and it pushed really bad as well. If you are not running sedan put a lola on it, it will turn then. 37 Fronts will usually give you the off throttle steering your looking for as well.
Just a cuople of things to try if you haven' t allredy.
Brad
Brad
Hi Brad,
I have tried running the front diff looser, but it made such a minor difference on the car's performance, I think I have to pursue other areas. I will be changing from my McLaren body, since I am having a bit of a problem with engine heat and also the massive body overhang (front tucks under on occasion). We are not allowed to run Lola bodies, unfortunately... they were banned from our club last year.
Thanks for the ideas!
Re: Re: Re: Re: ATTENTION: TRACTION ROLL...Help!Help!
Originally posted by kumpol
Here is the picture of the track that "PROFICAR" mentioned. There are around 5 or more 710s racing every week. I haven't seen anyone has a problem with traction roll. We all have the front one-ways locked....we drive very hard.....even harder for PROFICAR (16.7s laptime).....he is one of the fastest guys at our track.....
I also copy his setups and.....my 710 getting faster and faster....
Re: Re: Re: Re: Re: ATTENTION: TRACTION ROLL...Help!Help!
Originally posted by Sow&Steady
where is this track kumpol? Looks technically challenging!
Re: Tires for sale
Originally posted by GlennCauley
Hi all,
I have to liquidate a bunch of foam sedan tires (for my S710), and I wanted to know if anyone here is interested.
Please see the For Sale forum on RCtech.net. E-mail me if you are interested.
Hi all,
Below is the setup I am currently running on a relatively short, technical track. The car has push into and through corners, but comes out very well.
I would like to get some advise on things to try to get more steering at corner entry and mid-corner.
At the bottom are a few things that I am considering changing to improve steering.
Harder rear tires... hehehe. That is so unlike what I am used to running on a sedan. But I will give it a try too.
Also, don't be nervous about losing the front roll bar, either. That is another change that I have gotten positive results from.
Another change that works well is standing up the front shocks. It does very well in making the car turn in more aggressively.
Also, try moving from reds to yellows in the rear as a means to free the car up by keeping the weight in the center. I find that it helps in rotation and in turn in. I actually got better turn in running identical springs front/rear rather than stiffer in the back.
I run a narrow front track width, but as a change it did not seem to make much of a difference.
Have you tried the locked front axle?
Re: Re: Re: Short track setups
Originally posted by kreidel
Thanks Proficar, is this the setup you use at TFB? I am going to be in Kennesaw the 2nd weekend in July and I am bringing my gear so hopefully the weather is nice and I can run with you guys.
Originally posted by mariochi
THank You PROFICAR BUT.....
I have already tried your setup with 37front and 40 rear and yellow spring all around.....
The results is that the car roll-over after5-10 minutes of race (instead of after 20 minuts of race)..
....If you drive "HARD" YOUR CAR YOU WILL ROLL OVER
No ... it is quite true...
I have tried 37fr /40rear but I didn't tried yellow spring togheter....
It works on a Small technical well gripped TRuck???
Or it makes the car too glued to track and low to react (sluggish)????
Try running the same tires you run now (40/40), but change your shocks back to stock...with the 30W oil and yellow springs with 3 or 4 open holes front and rear. It does not make the car sluggish, that's for sure.
Originally posted by Julius
I saw on your setup that you run the DRS in the up position. You may want to try the lower position. That might create a little more rear grip in the second part of the corner.
Did you try the front shocks more vertical?
It is important to find out if just before rolling the rear slides or that the car just rolls because of too much side grip.
SO.....WHAT DOES IT MEAN????????????????????????
Please tell me
P.S.front shock more vertical is IMPOSSIBLE WITH LOLA body and Lolashocktower.
Originally posted by Picard
I aggree with you mario, I have found that I have too much grip at the moment and it it washing away speed through the corners of my track.
I am trying a few different things this weekend (Higher shore tyres and different roll centres)
Originally posted by Proficar403
Your setup just looks too stiff...blue/red with 50w.
it is :
SLUGGISH
YES IT IS FOR ME.
SO :
i will add 42 shore all around or...
I will retry red spring all around
Re: Re: Re: Re: Short track setups
I have run fastest without the front roll bar, but that sometimes makes the car unpredictable in lower traction.
