Serpent 710
D... I just realize that you said you use Futaba but advertising KO as your signatures.. I guess that`s what I thought you were using. Or do I get confused again
Re: Re: Re: 705 CVD's on 710?
Originally posted by Brightbluehaze
My buddy says the outdrive has 4 slots in it as opposed to the normal 2 that the kit comes with?
http://www.mytsn.com/products/product.asp?prid=250
The optional Hudy ones (stronger) are 4 slotted and can be used for the front and rear of the 710.
http://www.mytsn.com/products/desc.asp?prid=249
I use Futaba. KO in my sig is just to disturb someone else I know. Anyway KO gears are very good. I like their servos especially. Given the opportunity to start again, I would not mind getting the Helios.
Originally posted by CraigH
Would really like a 710 to put the smack down and dethone the mtx3 of the track records.
Re: Re: Re: Roll Center position question
Originally posted by kreidel
Look at the setup Poalo gave for Kissimmee regional and maybe you can explain what the rear positioning is?
Roll-center position upper: low inner (UBI)
Roll-center position lower: low (LB)
That would be stock out of the box setting.
Originally posted by FW05R
no the novamega would not be legal at my race track but its only a 20 dollar difference from the tsr12 and the novamega if the novamega is a better engine why not?
Bought a Pro4 instead. Decided I would only run electric this year. But after the parts problems HPI has.The Pro4 is going to be sold and Im buying a Xray or 710. Have to see how the finances go. We have one guy here in KC that has a 710,every one else has MTX3s. Would really like a 710 to put the smack down and dethone the mtx3 of the track records.
good luck
Re: Re: Re: Re: 705 CVD's on 710?
Originally posted by InitialD
I would not know about how the CVDs are constructed but for the normal dogbones that the kit uses, it comes with outdrives with 2 slots front and rear.
Now I am wondering should I just go with the 3racing CVD's for now or should I go back to good old dogbones?
Is there anything detrimental about going with 3racing ones?
Re: Re: Re: Re: Re: 705 CVD's on 710?
Simply no maintenance.
If I were you and if that were the case, I would go with the NovaMega. But that's just me because we run outlaw.
but there is something about the 710 that got my attention
I took apart the other side of the car and the other outdrive looks to be Hudy springsteel (Brownish in color) however the outdrives do not have the holes drilled for the pins that lock the front oneway making it a solid axle. I assume the Hudy ones would have these holes?
http://www.mytsn.com/products/product.asp?prid=3362
I think the reason why the outdrives do not have holes is because the original owner changed them. If they are 4 slotted, brown in colour, my bet is they are the 808222 ones for the Impact / 835 option.
http://www.mytsn.com/products/product.asp?prid=369
These outdrives are lighter and of course does not have holes on the shaft for the front solid axle conversion. Either you drill them yourself or use the original 710 ones back if you want to use the solid front axle conversion.
Re: Re: Re: Re: Re: Re: 705 CVD's on 710?
Are you referring to the original oneway outdrives with the hole for the solid axle pin?
I dont see any way these dogbones could come out at 199mm front trackwidth so I suppose I will just run the car this way for now and if I have a problem I will order the 3racing universals.
Thanks once again for the assistance.
One more question what would be the best starting point for getting rid of a highspeed on power push with the car? Off power is perfect, low speed on power is a bit loose (mainly because of tirespin) but highspeed through the sweeper it is very hard to get back on the throttle without some pretty drastic pushing!
I switched to red springs all around which helped somewhat then went to red fronts and the pink xray rears hat came with the car and this helped even more but the push is still very evident when getting back on throttle through the sweeper.
Perhaps it's the dark side ! Hey, why isn't the FW05R a choice?
And what can I say I fell in love with this car once I started building it
