Serpent 710
Old 04-25-2004, 03:44 AM
  #8866
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Originally posted by InitialD
Cool. Good luck on the business venture.
Opphs... Crashed_1 would probably be elated to hear this ! I hear he's a big KO fan now.
Thank you.
I hope I could get this business venture to make enough money to stop working.
I'm hoping it does well enough to open my own track.
PSI Racing is offline
Old 04-25-2004, 03:49 AM
  #8867
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Oh Harry, you're fighting an unworthy cause. Get a life trying to convince people that Serpent is made in China ! Get back to your own threads or if not at least post something useful here.
Besides, you never know that the 100 odd cars you own (including NTC3 and R40) are made in the good old China (whatever that means).
I'm not trying to bash, but HPI seems to be promoting the Savage more than the R40.
They had a full size version of the Savage (real truck) at RCX.
At their booth, they had like 3 Savages, and only 1 R40 on display.
My cousin is getting frustrated at HPI's lack of support as is thinking of buying a 710 or 950R off of me when I get my Serpent order.
Old 04-25-2004, 03:53 AM
  #8868
PSI Racing's Avatar
Default Re: Re: RCX
Ummm, I thought Pyramid or Goldfinger mentioned that the setup tools are already coming with holes that are aligned for the 710...
I haven't seen any of the newer versions here in the states.
A new version might be out in places other than the US.
I'm just relaying what the Hudy guy told me.
The guy from Hudy told me that they're re-tooling the setup tool to fit more of the cars that are out.
Old 04-25-2004, 04:11 AM
  #8869
Registered User
Pyramid's Avatar
Default Re: Re: Re: RCX
They guy from Hudy told me that they're re-tooling the setup tool to fit more of the cars that are out.
I think you are right. US often get things late. Should be the fastest since r/c market is really big down there.
You guys don't play on Sunday
Pyramid is offline
Old 04-25-2004, 04:17 AM
  #8870
PSI Racing's Avatar
Default Re: Re: Re: Re: RCX
I wish we got things here faster and cheaper.
As for this Sunday, I'll still be at the RCX show.
Old 04-25-2004, 05:05 AM
  #8871
rwisejr's Avatar
Originally posted by jfc_tech
to continue....
since then, I never go into A-main again...
i cherish those moment...
Keep your head up you will get there again just keep practicing and learing your ride that is the key.
rwisejr is offline
Old 04-25-2004, 08:27 AM
  #8872
Wap
Default Re: Re: One Way
Originally posted by PUNISHER
If you were using the right lube for one-way bearings I wouldn't worry about how much you use as long you use it!!
thanks punisher, also i have the lock set for the one-way. My question is should i install the collar that came with the lock set and keep the collar on all the time if i want to try the solid axle all i have to do is insert the pins.
thanks. also i don't know if this question has been ans. but can i buy a switch holder from serpent or will i have to make one.
Wap is offline
Old 04-25-2004, 08:30 AM
  #8873
Wap
Originally posted by Marcos.S710
cool ,here is a picture of my home track
mark you guys are luck to race on a cool track. We had a track like that in Houston, Texas, but the owner was a jerk so no one came. I am moving back to Houston and maybe in a year or so we will have another great tract design for 1/8 & 1/10 gas cars courtsey of me.
Wap is offline
Old 04-25-2004, 08:37 AM
  #8874
markp27's Avatar
Default Setting throttle max travel.
I decided to set my max throttle travel, by watching the throttle slider inside the carb. I adjusted its position (holding the throttle trigger fully depresed) until the throttle slider was no longer visible whilst looking into the carb.
Does this method set the max travel accurately, i.e. give max possible throttle?
Cheers, Mark.
markp27 is offline
Old 04-25-2004, 08:45 AM
  #8875
cox049's Avatar
My scuderia (If I can load the picture...)
cox049 is offline
Old 04-25-2004, 08:49 AM
  #8876
cox049's Avatar
Otra
cox049 is offline
Old 04-25-2004, 09:08 AM
  #8877
markp27's Avatar
Nice! Did you use silver on both of them, or is the one on the left grey? Looks good.
The one on the right seems to have seen some action
markp27 is offline
Old 04-25-2004, 09:20 AM
  #8878
cox049's Avatar
How do you think I became an expert in front bumper replacement?
The newer one has light coat of silver (all I had)and than white.
Hey Mark, yours looks white, I thought it was silver
By the way, its nice to see some really very good paint jobs in these last pages!! Keep it up fellas
cox049 is offline
Old 04-25-2004, 09:52 AM
  #8879
markp27's Avatar
The silver one is on my Tamiya EVO III - a test run for the new colour scheme
I found that silver is quite a heavy paint, though and so this timeI thought I would try white instead. It does indeed make a weight saving: the bigger 200mm body weighs two grams less than the silver painted 190mm - proportionally a very big weight saving
But I'm not too keen on the white and next time I'll probably try grey or paint the rear section sky blue, in keeping with the Dutch national colours.
Cheers, Mark.
markp27 is offline
Old 04-25-2004, 10:17 AM
  #8880
Pit-racer's Avatar
Believe it or not , I put a parma on-road frt. bumper brace on and went full throttle into a parked car. I only shattered a frt. shock tower, everything else was fine.
Pit-racer is offline
