Serpent 710
#8761
Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Originally posted by BaxterC
So you can get KO servos and sell them for less than $95???
Will you be an online store?
Will you be able to ship to South Africa?
Will you have Bodies? And paints, and be able to process credit cards?
And will you be able to sell... Serpent products?
The KO servos are hard to sell for that cheap.
I would only be making a 20% profit if I sell it at that price.
The hard thing about selling KO in the states is other countries get a lower cost on them.
I live about 1/2 an hour from Proline/Protoform.
I haven't set anything up with them yet.
Getting more manufactures on my list is one reason for going to RCX this weekend.
I want to see what's going to be coming out.
Yes, I will be doing internet sales and I will be able to process credit cards as soon as my site is up.
I'll see about shipping to South Africa.
I don't know what shipping would be like.
#8762
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Originally posted by PSI Racing
I'm going to work on Serpent next week.
#8763
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
If you can do serpent and ship to SA and be reasonable, You have a customer.
Give me about a month to get my site up.
Do you guys have paypal there?
#8764
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Alright.
Alright.
#8765
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
No, we dont, I wish as it would make life easier, we have good old visa and mastercard only. I may start looking for some parts for my 710, I dont order so often, but I order big when I do. RC mushroom are smiling... over $1000 in one shot.
Cheers, Mark.
#8766
#8767
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: VIP CARD
Originally posted by markp27
You can transfer money onto a paypal account using your credit card.
Cheers, Mark.
Cheers, Mark.
#8768
Originally posted by Pyramid
A bit longer on total length and also from pin to end of spur.. 6mm (inner diameter) precision shims would do the job find to remove a little sloops on the first spur gear. But the weight saving is much more important since it TURNS...
There is one problem with the 3racing upper bumperplate though: They forgot we like to fit an AMBrc DP transponder underneat it but the aluminum part that holds the up-stop setscrews prevents this. So I had to mount it on top...
Also got 2 sets of 808220 "PRO"driveshafts which are.... black
And about rotating mass off the Ti shafts:
The main difference is that the middle and 2-speed shaft together take about 15g off the total weight of the car. The difference in rotation resistance is sooo very small, nobody will notice it.
I think Julius mentioned this before.
#8769
Originally posted by KevinS
I received the parts today and found no problems fitting the 2-speed shaft and the same goes for the upper bumper plate.
If the shafts of the hudy drivers are black, then I am sure the dogbones should also be, or am I wrong?
Check it out, I am an Addict... this I must admit, is true, I am.
#8770
#8771
Re: Re: Roll Center
Oh yes, I think the roll axis play more important role for that matter.
Here is the original question:
What I`m interested in, what is the benefit for having higher RC but with the lower arm mounted far more toward up from the bottom of chassis. I mean, when the lower arm is now mounted on its highest point, the weight of the rear (CG?) is somehow lower. Does it then generate more tracktion??
#8772
808220 dogbones
Oh, about the 808220 spring steel dogbones, I was incorrect.
They ARE shorter in overall length than the original S710 dogbones by a little bit less than 1mm.
The pins are also closer together by approx. 0.5mm.
Hmmm... my shoe tastes terrible this morning...
#8773
Re: 808220 dogbones
http://www.ashfordhobby.com/PDF%20files/SerPrice.pdf
This is the FULL serpent line at ashfordhobby.
I am sure that the bogbones were brown, but there is more than one person conplaining that they are black. maybe they changed the colour?
