Serpent 710
Old 03-06-2005, 08:27 AM
  #20446
InitialD's Avatar
Originally posted by paulfitipauldi
I have a few questions , first about Centax ,, the coil spring that I received in my Kit was the Gold one, my manual says 909518 , is that OK, so should I replace it with the silver one Ser6586??
The manual is wrong. The gold one in the kit is part number 6586. It's 1.7 mm diameter spring and softer than the silver one that comes with the Centax II (1.8 mm).
You may have problems setting the Centax clutch. If you can get the yellow Centax 3 clutch shoes (802509), then it will solve the soft engagement problem. If you cannot get it, try and mount the 3 piece flyweights in between the 3 pins of the flywheel by cutting them short and just enough to sit them in between the pins. This will give bettwer clutch engagement with the stock black clutch shoes.
If you want a harder punch and clutch engagement, you may want to get the harder Centax II spring (silver) from the 705 to replace the gold one.
another question, I see that in your last setup , you're running locked front diff, did you locked the one way or the ball diff??,, and what did you do to lock it???
I locked the front oneway with the 802252 front shaft lock set. You can also lock a front ball diff but that would mean "destroying" your diff plates. I believe the way to do it is to create dimples in the diff plates for the diff balls to sit in and locking itself when you tighten it.
One more question, sorry but the UT and LT thing, I don't understand the terminology already,, due to my little experience with the car,, can you please make a drawing or take a pic. about this concern,,, BTW, thanks for the setting , that was I'm looking for ,, I'm running technical tracks around here!,,
Paul, refer to page 17 on the small setup booklet given with the 710 kit. It shows you what the terminology means. You basically have different combos to change the rear roll center. In short, if you set a high rear roll center (which I did), the rear rolls less. Vice versa if you set to low rear roll center. Roll center affects how the car behaves on the track. It can make the car lazy or can make it twitchy.
If you have more questions, shoot.
InitialD is offline
Old 03-06-2005, 08:28 AM
  #20447
paulfitipauldi's Avatar
Originally posted by InitialD
Nice ride Paul ! Hey welcome back...
I know sometimes it seems easier if we can just put the car in the washing machine to give it a good cleaning...
That's the only place in the house that my wify let me works on!
paulfitipauldi is offline
Old 03-06-2005, 08:43 AM
  #20448
Ok cool,,, what if I replace it already with the silver one,, have no tested yet, do I have to do another mod to engage hard?? still have the black clutch and weights in his original positions
Originaly posted by Initial DI locked the front oneway with the 802252 front shaft lock set. You can also lock a front ball diff but that would mean "destroying" your diff plates. I believe the way to do it is to create dimples in the diff plates for the diff balls to sit in and locking itself when you tighten it.
Ok ,, I'm using the one way diff too locked position, with the old drive shafts adaptors,, I cut it to 25.54mm, and locked with grub screws instead of Pins!! the 710's drive adaptors are kind of weak for me
Originaliposted by Initial DPaul, refer to page 17 on the small setup booklet given with the 710 kit. It shows you what the terminology means. You basically have different combos to change the rear roll center. In short, if you set a high rear roll center (which I did), the rear rolls less. Vice versa if you set to low rear roll center. Roll center affects how the car behaves on the track. It can make the car lazy or can make it twitchy.
Thank you very much D,, I realy apreceate it,,
Old 03-06-2005, 08:54 AM
  #20449
InitialD's Avatar
If you set the clutch using stock parts in stock positions, get the yellow clutch shoes. You can try putting in the silver spring but I would not know if it'll solve the problem.
I suggest you go out and try the car in stock clutch setting first and see how it goes while you wait to order the yellow clutch shoes. You may want to change them to the yellow shoes in any case, as they are much better in terms of performance.
I don't know how you mount the grub screws but they may tend to back out and loosen after a few rounds... As long as you don't hit something solid at the front wheels while on throttle, you should be ok with the stock oneway drive adaptors...
Else, buy an extra set of diff plates for the ball diff, make 3 or 4 dimples on it symetrically and lock the front ball diff if you want a more durable front solid axle solution. Or try running a ball diff completely in front. You may like it better than the front solid. Set it tight.
When you use a front ball diff, makes sure you set a narrower front trackwidth because the dogbones can pop off. Try 198 mm. If you want to set it back to 200 mm, use wheel hex spacers. Cheap and free would be to make your own out hex wheel spacers out of lexan...
InitialD is offline
Old 03-06-2005, 02:42 PM
  #20450
Sorry about the grubscrew,, I should say Setscrew 3x4mm, of course, you have to make a dent in the drive shaft so the setscrew sit firmly in it, then put the collar that holds the pins, that way you prevent the setscrews don't come out
Old 03-06-2005, 05:57 PM
  #20451
alucard13's Avatar
Default Need some help with Kit
I just got a serpent kit and I am stuck on Step 2.3. The parts that are confusing me are 1. Where is bearing U7 (either i lost it or it ddnt come with it)? and what do i do with the snap ring? On the diagram it looks like the bearing goes on top of the snap ring but i dont think thats possible. any help is appreciated.
Next thing is where can i get parts for serpent online like the u7 bearing, serpent cleaning putty and one way lube?
***EDIT****
I got it. It does go inside and bearig does go on top.
alucard13 is offline
Old 03-06-2005, 06:37 PM
  #20452
InitialD's Avatar
InitialD is offline
Old 03-06-2005, 08:14 PM
  #20453
InitialD's Avatar
Default Re: Need some help with Kit
Welcome aboard alucard. Where are you located?
Try www.rc-mushroom.com.
Oneway Lube
Cleaning putty
And don't forget the *spit* Super Grease as well...
InitialD is offline
Old 03-07-2005, 12:57 AM
  #20454
FW-05RR's Avatar
nice ride paul
FW-05RR is offline
Old 03-07-2005, 01:52 AM
  #20455
Darth Vader's Avatar
Initial D,
You've got PM
Darth Vader is offline
Old 03-07-2005, 07:04 AM
  #20456
crashed_1's Avatar
Originally posted by Darth Vader
Initial D,
You've got PM
Hey Lord Vader...use the FORCE. No need for PMs...
crashed_1 is offline
Old 03-07-2005, 07:05 AM
  #20457
alucard13's Avatar
Default Re: Re: Need some help with Kit
Oneway Lube
Cleaning putty
thanx for the info. I am in Miami. I race up in Palm Bay sometimes. I have a Mugen MTX-3 but alot of the racers at RPR here in miami use Serpents so i decided to give it a try. I hear its a good car but fragile.
Old 03-07-2005, 07:14 AM
  #20458
InitialD's Avatar
Default Re: Re: Re: Need some help with Kit
I guess the reason being it's very light... In fact almost under the legal weight.
If you're in Fl, you should not have any problems getting those parts, no?
InitialD is offline
Old 03-07-2005, 07:26 AM
  #20459
alucard13's Avatar
I have a hobby shop just a little ways away that sells serpent and the guy who owns RPR track just openened a shop online and sells the parts trackside.
Old 03-07-2005, 02:25 PM
  #20460
Originally posted by FW05R
nice ride paul
Thanks!!
