Serpent 710
Re: Re: Re: Re: Re: New Track
Originally posted by Picard
Sorry having a few problems with the transporter at the moment.
Originally posted by markp27
Too old, hey there's always the masters, you know
new serpent kits 710
some people said the new serpent kits have some upgrade in centex, shock tower, bumper plate etc.....does anyone buy the kits and tell the difference ? My kits was the first batch and I wanted to know if it is worth to the updated kits ? thank you
Re: Re: Re: Re: Re: Re: New Track
Originally posted by InitialD
If those old folks cannot wait or if they think that by 2006 they are too old to enter competition, they could register themselves for the 1/5TH lawnmower onroad WC in Lostallo, Switzerland. Date is scheduled for August 18-28, 2005.
Re: Re: font belt issue
I would not worry too much about the front belt rubbing. Mine has always done that. If you have a milling machine at your disposal like Pyramid or Goldfinger, you could mill that part of the chassis so that the belt clears.
I don't know about the "serpent metal front belt mount". Are you referring to the aluminum mid bearing block? I have no idea that this will "solve" the belt rubbing issue. Mark? Onkel Sow? Picard? Sparsky?
Re: Re: Re: Re: Re: Re: Re: New Track
If 45mins is too long for them to stand, maybe we could arrange some wheelchairs?
Naaah... The 1/5th scale lawnmower class sounds better.
Re: Rear Roll centre
I heard you mention a little while ago that you thought the default rear setup worked a little better with the high front rol centre because it allow the car to roll better around corners
I am interested in trying it next race meet. My rear is too loose with upper inner and low rear roll centre. I have tried everything
Like I mentioned earlier, the RC would depend a lot also on your overall setup. I would look into the other stuff first before playing with the rear RC. If the rear is loose, I would tighten the front sway bar some more. Make it more stiff. Less rear droop. More rear camber.
Your right D
I was referring to milling down the chasais although I have not done this and my front belt if fine.
Re: Re: Re: Re: Re: Re: Re: Re: New Track
No need, Sow and myself have specially constructed carbon fibre Zimmer Frames
Re: new serpent kits 710
If you're casually playing and racing at club level, I suggest going with the stock parts first and when you break them, then you could replace them with parts that are with stronger plastics which is a running change that Serpent is doing.
Sow's really going to hate winter in the UK
But Onkel Sow can always escape winter when he steals time and come back to Malaysia. Sunshine 24/7 throughout the year.
Don't even mention that word. After the luxury of running when I wanted to at the AMCC track, now I have to go back to the Lawnmower infested track here in Nuremberg. But there again, with all the leaves on the circuit, it will hardly be useable until the spring
Re: Re: Re: font belt issue
Originally posted by crashed_1
No it doesn't...
No it doesn't...
How is the front belt so far? Any problems?
