Serpent 710
Old 09-18-2004 | 12:13 PM
  #15766
markp27's Avatar
One thing to remember when talking about the spilt sizes (front-rear) is that this also dictates the amount of overdrive. For example, if you look at the overdrive table, you'll see with tyres of equal front-rear diameter, you'll get an approximate 1.02% front drive advantage - good for wet or slippy conditions.
If the tyres are mounted so that the front is 1mm smaller than the rear, then the split is all but a perfect 1:1 split. This provides the highest top speed, but probably not quite the same performace out of the corners as the 1.02% front drive advantage.
Cheers, Mark.
markp27 is offline
Old 09-18-2004 | 01:58 PM
  #15767
Sow&Steady's Avatar
Cheers, Mark.
couldn't explain it any better ... R E S P E C T A !
Sow&Steady is offline
Old 09-18-2004 | 02:03 PM
  #15768
markp27's Avatar
Thank you, oh Master BTW, Sow: Ali G says, Restecpa
markp27 is offline
Old 09-18-2004 | 02:19 PM
  #15769
Sow&Steady's Avatar
I know but I'm Ali SS.
Old 09-18-2004 | 02:23 PM
  #15770
markp27's Avatar
yous is a wicked main man
markp27 is offline
Old 09-18-2004 | 07:23 PM
  #15771
Pyramid's Avatar
Registered User
Hmm ... you find that it gives a lot more acceleration? The internal ratio becomes 1.917.
Does this pulley fit perfectly fine on the current ball fidd hardware? I have the part but its in my 705. Wouldn't mind trying it out on the 710 if the acceleration/pick up improves!
I use 2.5mm split so still 1:1 in ratio. My only reason to use 46T is to get the closest possible tire wear for the entire 45mins final (consistent performance). With 45T, I always end up with much smaller rear (1mm split in the beggining) like 2mm smaller as far as I could remember.
To fit SER-6357, here is the only way to do it..
Please refer to the black book (rear diff) for more info on how to put it in.
Pyramid is offline
Old 09-18-2004 | 09:53 PM
  #15772
packetdreamer's Avatar
which of you sissies were complaining about a busted shock tower?? i say, "THE SHOW MUST GO ON!!" (and i almost won, too.)
packetdreamer is offline
Old 09-18-2004 | 10:05 PM
  #15773
i think it has been asked, but, does anyone make good universals for the 710?
Old 09-18-2004 | 10:55 PM
  #15774
is there a transponder mount for the 710?
Old 09-19-2004 | 03:10 AM
  #15775
Sow&Steady's Avatar
pd, there's only holes made for a Personal Transponder, on the upper plate of the bumper.
For normal ones I just ream a hole on the front right of the windshield.
Old 09-19-2004 | 03:12 AM
  #15776
Sow&Steady's Avatar
Not at the moment ... in my opinion. I've seen and heard that the ones made by 3-Racing does not last but I've not tried it.
A few folks mentioned that Michael Salven used some combination of the Hudy spring steel stuff from an XRay car. Don't know how that works but you can see it in the WinterNats video.
Old 09-19-2004 | 03:13 AM
  #15777
Sow&Steady's Avatar
Lo and behold! The new Mechanno 710!
Old 09-19-2004 | 03:16 AM
  #15778
Sow&Steady's Avatar
Pyramid, thanks for this. I'll refer to the Black book.
Old 09-19-2004 | 11:33 PM
  #15779
InitialD's Avatar
Info for these items are officially out on mytsn.
Diff clamp-ring 2 parts S710
Anti-roll bar rear set 2.5 +3mm
Engine monoblock M12
Somehow I prefer the look of the one piece engine monoblock from East.
Also, did any of you notice that the newer parts come with bags that are with orange designed tags and not the old purple one?
InitialD is offline
Old 09-19-2004 | 11:47 PM
  #15780
TitaniumR's Avatar
Noticed the engine sits rather high on the std purple two piece engine blks. Does these one piece one lower it? I think the engine can be lowered another 1 or so mm without the flywheel coming thru the chassis slot. Thanks.
BTW, finally tried the car with 15 size max. First run and it's awesome. Will need some fine tuning to improve.
TitaniumR is offline
