Serpent 710
Spare parts
Hi all,
Check this:
http://shop.the-border.nl/customer/p...9b8c20703682c3
Finally spare parts available in Europe!
Thomas
Check this:
Thomas
Originally posted by Pyramid
came accross this pictures when browsing for LHS in Japan,
came to re-realize, Europe.. still the standard of performance car
forget the car!!! i think that guy is wearing a genuine giorgio armani suit!!! NICE!
Re: Spare parts
Originally posted by 840918001
Hi all,
Check this:
Thomas
Hi all,
Check this:
Thomas
Originally posted by packetdreamer
i think we are going to have to start closing this forum at night.
For your refs,
PS: These are limited time offer items.. so if you want them, try to get it ASAP from your LHS. Main part number may differs on LHS.
SER-100006 contains S710 OPTION PACK
1 OF SER-802831 Set-up wheels S710 alu orange (4)
1 OF SER-801157 Bracket tank-mounting carbon
1 OF SER-802165 Pully adaptor alu. light (2)
1 OF SER-802155 Bracket middle shaft alu
1 OF SER-802325 Pivot inserts lw mid-pos (8)
1 OF SER-802252 Front shaft lock-set
1 OF SER-802241 Anti-roll bar levers + ecc. Alu
1 OF SER-909410 Shock-body alu teflon front (2)
1 OF SER-909411 Shock-body alu teflon rear (2)
SER-100007 contains S835 OPTION PACK
1 OF SER-808251 Middle bearing block 4wd aluminium
1 OF SER-808266 Pulley-adaptor alu light (2)
1 OF SER-801219 Pivot-ball 8.5mm alu coated (4)
1 OF SER-909218 Anti-rollbar levers alu front (2)
SER-100008 contains S950-R OPTION PACK
1 OF SER-909335 Rear anti-roll bar set adjustable
1 OF SER-909397 Conversion 51T pulley-eccenter-bearing
1 OF SER-909251 Pulley-adaptor alu light (2)
SER-100003 contains S710 RACE PACK
1 OF SER-802205 Bumper-plate TC
1 OF SER-802206 Bodymount plate TC
1 OF SER-802217 Suspension bracket front left
1 OF SER-802218 Suspension bracket front right
2 OF SER-802219 Wishbone front upper 1 (left+right)
1 OF SER-802221 Wishbone front lower left
1 OF SER-802222 Wishbone front lower right
1 OF SER-802316 Wishbone rear upper left
1 OF SER-802317 Wishbone rear upper right
1 OF SER-802318 Wishbone rear lower left
1 OF SER-802319 Wishbone rear lower right
1 OF SER-802320 Trackrod rear lw nylon (2)
2 OF SER-802330 Up-right (1)
SER-100004 contains S835 RACE PACK
1 OF SER-808120 Bumper
1 OF SER-808130 Bodyplate front
1 OF SER-808203 Wishbone front top left
1 OF SER-808204 Wishbone front top right
1 OF SER-808205 Wishbone front bottom left
1 OF SER-808206 Wishbone front bottom right
1 OF SER-808207 Steeringblock left
1 OF SER-808208 Steeringblock right
1 OF SER-808356 Wishbone rear top left M2
1 OF SER-808357 Wishbone rear top right M2
1 OF SER-808358 Wishbone rear bottom left M2 99
1 OF SER-808359 Wishbone rear bottom right M2 99
1 OF SER-808311 Up-right low (1)
SER-100005 contains S950-R RACE PACK
1 OF SER-902105 Bumper
1 OF SER-902106 Body-plate front
1 OF SER-902225 Wishbones front upper left
1 OF SER-902226 Wishbones front upper right
1 OF SER-902227 Wishbones front lower left
1 OF SER-902228 Wishbones front lower right
1 OF SER-902303 Wishbone rear upper left adj
1 OF SER-902304 Wishbone rear upper right adj
1 OF SER-902305 Wishbone rear lower left
1 OF SER-902306 Wishbone rear lower right
1 OF SER-909211 Steeringblock Left Wide Off-set (WOS)
1 OF SER-909212 Steeringblock Right Wide Off-set (WOS)
2 OF SER-909315 Up-right (1)
Originally posted by markp27
All well and good, but his night is my day and my night is your afternoon
For your refs,
For your refs,
Originally posted by Sow&Steady
... and notice the Toni & Guy haircut with Moogen grease on it!
seriously i love those lams. one fool here in scranton, pennsylvania tried to own one and learned that if you potholes can't tell the difference between exotic cars and hoopties.
You should be able to get them from every good hobby shop - Futaba are a very well known brand and the 9550s are the most popular servos for electric cars.
Try www.rc-mushroom.com for example.
In Europe I can get them for €100 but in the states, you should be able to get them for under $100 each.
http://www2.towerhobbies.com/cgi-bin...50&FVPROFIL=++
i wish someone would get at obtrusive vehicle out of the way so i can see his shoes.
What`s happened to Bartex, he`s not around anymore..
Today he's missing and so is 3hobby.com!
Today he's missing and is 3hobby.com!
Again
Again
I'm doing something about it though ... thanks to some friends from this forum.
