Serpent 966
#2206
Hi I'm new to on road racing.I just bought a 966 te v2 and I'm worried that they will stop making parts for it now that the viper came out. So should I worry about that or I'm I ok
#2207
Serpent parts support is excellent. I can still get parts for my 950R.
#2208
#2209
selling a 966 roller, check it out here: http://www.rctech.net/forum/r-c-item...ent-966-a.html
#2210
how much length the rear shocks must have when the TE rear stand offs be used?
#2211
rear shock length
Very simply, it depends on the downstop (droop) height you are using. When you disconnect/unscrew the lower ballend and set your downstops during your set-up routine, after you set your rear down-stops, the shock length should be 1.0 mm past/longer than the 3mm shock screw. Just unscrew the long ball-end until your reach this length and make them both the same exact length. Thats it!
Paulie
#2212
I done it this way and I ended with 15mm length.
Something more Paulie.
Can you share a set up for medium traction,medium length track? I have the 966 with the rear shock stand offs but not the front TE front upper arm unit.
#2214
#2216
#2218
#2219
you "had a 966" :)
#2220
Bump on this old post for us running with old fashion cars .....
I run a 966 TE v2 and am struggling to get parts for it ; 903259 , 903359 , 9003281
many shops are out of stock
any idea ???
any idea ???
