MTX 5
#2582
We’ve been trying to avoid the issue of stripped gear and it seems that the recommended way (going for softer, low-friction belts, soft spur gears, and one-piece engine mount/new chassis) is the only way. I tried the EVO-Workshop multi-flex chassis though and it works as fine! No problem even when I used the original rubber belt, default spur gears, and the original engine mount. Give it a shot, peeps!
(BTW, I think the new Mugen Seiki chassis doesn’t balance quite well, with the below-engine hole filled up…)
#2583
we still use all the old stuff but have installed brace from trackside QLD//AUS WE USED BRACE FOR 6 DAYS AT AUS /NATS and only chipped a gear in final ONE TOUTH// CHASSI WAS STILL STRAIGHT so no complaints used modded rossi
greg
greg
#2584
#2586
Fukuda left mugen for km racing team? What's with mugen and their team drivers always jumping ship? Just thinking?
#2589
he left from Nova rossi to Picco then from Mugen to KM
#2590
Who's using the new chassis?
Hi guys,
What do you think of it?
Does it seem stronger?
What about handling, is anyone noticing any difference?
Anyone trying just the new chassis and using two piece engine mount, what do you notice?
Steve Hanwright
Steve Hanwright
#2592
What's the battery pack of favour.
What's the battery pack of favour?
What's everybody using.
I'm using the intellect 1600 Mha LiFe.
I find it just fits but I would like it to be a few mm shorter. It runs close the middle shaft and I'm concerned about it getting damaged if a belt shreds as I run my wires out at this end.
Steve H
Steve H
#2594
Shawn I have tried pretty much everything...here is my 2 cents..the stiffet chassis is great for giving u more breaking power...one piece motor mount is the key for solving the stripping of gears problem...I havent tried the new gears cause the problem stopped after installing the mount...when I strip a gear I will try the new ones an post what I think...but. it been about a gallon since the last gear stripped..
#2595
Where do you exit the wire
Hi mate,
I was just wondering about the wire routing others use.
I have no problem fitting the battery, but because I exit the wires at the front inside this means the wires are close to the mid shaft inner drive pullie.
It's no big deal but I reckon if I shred a front belt it will rip out the wires in the battery. I was wondering if other route the wire at the rear. As I might try that.
Steve H
Steve H
