Rc10ntc3
#9421
You'll have to find the RC10gt forum first through the search engine, and get help there. This is the Ntc3 forum....
Best Cheap Ntc3 upgrade: dynotech 19t pinion/aluminum clutch bell + ewhippler carbon driveshaft + tires that are at least 1mm smaller than your competitors....
#9422
After some grinding&flipping of kfactory front shocktower, I was able to lower my front shocks for a lower CG... Checkout my album "berty" tomorrow for a picture of the mod... It should make the front end a bit more reactive....
#9423
Happy thanksgiving.....
#9424
Time to lower the rear shocks by drilling the DD shocktowers...
#9425
Rear shocks lowered, and 12grams lost by chopping off the motor head. Down to 1648 grams now......
#9426
#9427
Wow!! Thats low great job bertrandsv87!!
#9428
Once you flip the carbon fiber piece of the kfactory shocktower, it becomes a short shock mount... Of course , you will need to dremel off the extra cf for the body mounts, but the standard shocks still have room to work...
#9429
#9430
I hope it will perform on par with the other cars out there...
#9431
Anyone know if tc7 shocks fit ntc3? I know the tc7.1 ones are too short.
#9432
I never ran the tc7 shocks before, but I know the tc7.1 shocks can be built to be long enough with longer shock end ballcups....
#9433
#9434
Maybe, but the best setups usually require very little droop, 2-3mm, at most, so I think it can work....
#9435
