Rc10ntc3
#483
Regional Moderator
Ellegi, fast tires (by Mugen) and a couple other brands are all made by Elligi...
I think your safe with any of those...as far as setups, what kind of track are you running on?
I am running mostly fast tires (re-branded Ellegi's) but I have had some luck with the Yokes in the past.
#486
Originally posted by AMGRacer
Mayby it was designed that way to fight torque steer from the shaft!
I saw nitrorcfan's car today and it was true as daylight. It seems as if the shock tower is cocked giving the right side less caster and the left side more caster. I loosened the shock tower screws and straightened out the shock tower which gave equal amount of caster on both sides. But as soon as you tighten the screws you can see that the shock tower get's tweaked causing the caster to get tweaked. I haven't had a chance to check my car but I'm kinda curious to see if anybody else is having problems.
Normally, I would be a little peved about these little tid bits of poor quality control but this is expected with any car that hits the market...well...almost. The one main exception to that is the Xray. I built many cars and have seen many people do all these mods like shaving and grinding here and there and doing this and that. But with the Xray...everything goes together smoothly and precisely. With the new optional parts out it will be quite a contender on the carpet tracks.
#487
Registered User
That has to be a mold problem. I just sit down and checked every height and every adjustment and everything is the exact same. Even my shocktowers are the same height. There was a machine problem with the electric TC3 in the begining but it does'nt seem to be in my car. I hope the carbon kit is ok I just bought one. Is everyone having troubles getting spare parts? I have had a oneway on order fo over a month.
#488
Spares are a bit of a problem.I broke a diff case last week and had a spare but I can't find another one to save my life(for the spare box).I looked locally for even a electric TC3 case but couldn't find that one either.(I think the only difference is the upper bumper mount hole)I guess I will just need to put a couple on back order
#489
The electric case and the NTC case are the same now.
as for uneven height arms are your tires equal height? and are the front caster clips evenly spaced? also make sure the front lower arms are in the right place. even though they fit front and rear the fronts have two bosses on them for the blade rollbar. I put the front lowers on the rear at first and didn't notice until I went to put the blade bar on. It shouldn't make a difference but you never know. also check to make sure the rack is straight when you measure it. a little right or left steering alters the height of the hub arms alot because of caster.
#490
I picked up a electric case today but it must have been an older one because it doesn't have the top front bumper screw hole or the rear shock tower mount.I will use it as an "emergency" spare till I get a gas replacement.
#492
Every NTC3 I've checked has the same problem so far. Take the tires off the front of your car. Now get your calibers and measure from the steering knuckle (where the big hole is that the steering linkage gets connected) to the table. My guess is that you'll see between a 2 - 3mm difference from one side to the other. The back knuckles measure the same, however, the front's don't. In some cases you can see it without even measuring it.
I have the left on the left and the right on the right and the caster setting is the same. I've replaced the knuckle, and the shock tower, however, still have the same problem. The bottom A-arms are correct because I have the blade connected to them. The only thing I have changed is the upper A-arm.
#493
I think the problem is where you are measuring this at. You are measuring to a point(the knuckle) that swings in a plane(due to kingpin angle (camber & caster)) that is not parrallel to the plane of the ground or chassis. Depending on your camber, caster and toe or steer angle, the point you are measuring to will go up and down relative to any other plane, such as ground/chassis. Why are you measuring this in the first place?
