Rc10ntc3
#2671
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Re: OS .12 TR (turbo version)
Originally posted by thefuzzclub
Just wansted to ask if anyone have tried this engine in your ntc3. Please advise if there will be modifications when installing the engine.
The OS is a bolt in...I think the turbo is only avail in a pilot(SG) version..so thats good....if you go for the regular version(TR),make sure you get the SG shaft too...
#2672
header
fast
i am using the gs one with no luck. is there any secret to keeping this sealed? or am i just doomed to a messy clean up every weekend
thanks
wvracer
thanks
wvracer
#2673
Be sure that both surfaces are both smooth and free of any dirt or grime. I have had no problems with mine. I just use the stock O.S. gasket.
Hope this helps.
Hope this helps.
#2674
I have the O.S. .12 TR , I cant seem to find the Low End Needle. Is it the same as the fuel control?
#2675
Re: header
Originally posted by WVRACER
fast
thanks
wvracer
fast
thanks
wvracer
Also, another trick a fellow racer gave me was to drill extra holes and use a second spring. It keeps the header up to the engine better and that should help your leaking problem.
#2676
I just did the nylon tape thing. Hopefully it does some good to my car. Or else 20 mins wasted.
#2677
Hey FastHarry,
I got my gearbox sorted out. A real simple solution that had nothing to do with the springs.
I overlooked the center set screw tension to the hub. I didnt have it tight enough and the shoes where actually engaging and slipping over the center hub.
Works great now.
Works great now.
#2678
good job!!
#2680
header seal
thanks for the tips folks i will give them a try i love to keep a clean car and all the oil just drives me crazy
thanks again
wvracer
thanks again
wvracer
#2681
jwf..whose front drive cup is that?....and how did it fit..
thanks.Harry
thanks.Harry
#2683
that came with the shaft also,right?....any problems with shimming,running,gear mesh etc?...
#2684
As for the leaking problem, I'm just using an GS gasket and it seems to work fine. I haven't had any major leaking problems with my TR. Occassionally a little excess, but fore the most part its super clean.
#2685
the shaft is an asociated shaft the drive cup is sold by it self
i just rechecked my gear mesh and it is fine. ive put this car
through 4 races where the main was 40 mins long and it
has held up. the only problem being my toe link in the rear
got pushed in. that is why i put a linkage colar in the rear to
help with that problem. it has been reliable since.
