Engine Wars Thread
#241
The project is doing well. It's about time to get down on it. I have to thank David and Ken at RD this would not have happened without their enthusiasm and desire to do this thing.
TG thanks for the email a while back. Sorry it was not feasable for me to do multiple projects at once. I think you will do fine.
Congrats to Steve for getting his engine launched.
to the readers of RC Tech forums, thanks for your support over the years. It is appreciated more than you know. It is what makes it all worth it.
Dennis Richey
Dennis Richey
#242
powder backing technology
An alloy you might find interesting is Duralcan from Alcoa
#243
Originally posted by Motorman
TG are you referring to powdered metal technology. I assume you are as that is the only way to get the silicon content way up. If so you will find that it is a common technology in the eastern USA. Alumunium Powedered metal parts can be had form many suppliers back east. I know the advantages of SI content but you get to the point where the alloy becomes to brittle and bang.
As I mentinoed before, I will have it in my hands hoppefuly by mid of November (P/S sets) will let know how it looks now. According to properties just perfect.
I was looking this technology last 6 month and so far didn't find anyhting, but will check it again.
#244
Dennice. I found Durlacan, it is just mixing technology wich make casting process easier, but still casting, not powdered backing, and Si content still low.
No, I will stay with mine.
Any way thanks a lot for directing to intersting technology. Will check it more carefully.
#245
just curious is this "powder backing" and "powder metal technology" the same as powder metallurgy?
#246
Originally posted by fastharry
hey stafan..did you catch that link I put up to the castor oil?..
#247
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally posted by stefan
No sorry, didn't see that. Could you probably post it again.
http://www2.towerhobbies.com/cgi-bin...?&I=LXS627&P=7
The guy said that this was what he was using...
#248
#249
Top Gun,I'm going to call you on Monday....
I will wait for your call.
You know the number.
#250
Originally posted by Top Gun 777
I guess, if I have enough english I just translate from Russian to English (my bad). It is technology , when all components in powder mix togehter and under very high pressure baking it in special furnes. If this is what powder metalurgy is, so we are talking about the same thing.
#251
#252
Serpent calls it micro casting
BTW, their piston according to my record has highest Si content.
#253
TG
Duralcan is just another method of creating a MMX composite alumunium. There are many resources including SIC Ni Graphite combos. its all in how its mixed. Duralcan is a brand name for an MMX powderd alumunium alloy. MMX sintered alumunium alloy composite micro forgings are readily available here.
#254
TG
TG
Here is web site with little bit explanation, very intersting, but very old: http://www.tms.org/pubs/journals/JOM...ofor-9711.html
I have plenty of material which I need and I can have it produce tons of it.
#255
my brief education in manufacturing processes mentioned powdered metallurgy. it is similar to what you said. a component or part can be produced first by using the mixed powder to form the part via pressure molding. the finer the mixed powder, the less "space" between the particles. the piece initially is very brittle and breaks fairly easily. the part is then heated to reduce the space even further and also hardens the material.
i dont know how strong the resulting piece is compared to a machined part or cast part, but i do know the benefit is that the process has almost no waste or scrap (like machining).
our campus has a lot of the machines that manufacturers would use. it was pretty cool learning how this stuff works.
