OFNA LD3 pro
#602
Originally posted by au_Nightmare
That hong-nor one is the same as my 2 "spares" and have same problem I believe.
hmm I'll PM you in a re: THS pipe
Here is a photo of what I done, I cut the pipe with hacksaw near weld and near pressure connector then "welded" the pipe back together.
Also cut a little from header to get pipe to sit back in same place.
I want to ditch my LD3 now !
#603
Re: fine pitch gear and new centax
Originally posted by jwf_frani
This new upgrade in gears is worth the money if you are going
to a larger track because you can gear the car higher. I race
with Steve Nguyen, Chris Verano of Ofna weekly and i can tell that their cars got a lot faster on the back straight and the new
centax seems to work good.
#605
Re: Re: Re: fine pitch gear and new centax
I don't really know who they copied but it does work good.
#606
Originally posted by Manticore
this is ugly !! horrible !! the worst pipe i have ever seen !!
#607
Originally posted by dtm
Ditch it over here....I can use it as a spare parts car!!!
#608
Yo Adrienne!!! I did ittt!!!
Ummm, yeah...ok..I just sent payment out for a Champ "Tangerine Dream"
Im sure, once I get it and start building, Ill have lotsa Qs...so be forewarned
One quick one I have...about the Centax...
Choosing to upgrade to the Mugen or even Kong Nor's version,
I see that the main reason is for more gearing choices...is durability over the "stock" clutch an issue as well?..I am thinkin of selling the "stock" system before I even build it...is this worth while???
#609
lol
aww come on guys stop bagging my test pipe :P lol, I know its rough but it was a test to see if a shorter pipe would be better and it would be so yeah im ditching the HN pipe (anyone want two new inline pipes? ) and buying something else..
#610
is the old/new/shoe type in 0.8 module? thinking of getting the mugen clutch. thanks!
#611
#612
lol
lol
#613
would the 0.8 module pinion mesh right if the spurs are 1.0? sorry, just dont know about these modules for gears.. thanks manti!
#614
lol
lol
Actually it looks as if it got gang banged
#615
That pipes nothing, you should see my last engine (crank snapped off just past flywheel - clutch fell off)
