Kyosho FW-05R
#5296
I tried to run the RRR, I could do a single lap quicker but overal the car was too tail happy and inconsistent where as the FW05 had a gentle understeer.
I have now switched to the G4S as this still has a solid rear end but has more steering than the FW05 (I am now a lap faster) but I am still using the FW05 for the Truck class as it handles better with rubber tyres.
#5297
what should I do to improve the steering?
#5298
(I assume you are running the RRR 2 degree front hubs?)
If it is for Rubber then use softer inserts in the front (soft front, medium rear).
#5299
thanx for your help
Edit: found it. vz201 2mm should help the steering?
#5300
Servo??
I lost two servos, what am i doing wrong, is it to close to the motor?
#5302
#5303
make sure you rubber mount the servo and do not have it tight
I also raise mine 1mm so it cleared the chassis when it moved
I lost 2 servo's until I did this and never lost another one since
#5304
I got some FW05 stuff sitting on the side collecting dust. A chassis and a full Kawahara middle conversion with the steel gears.
If anybody wants it let me know
Cheers
Cheers
#5305
HOW MUCH
WHAT STUFF DO U HAVE?
Cheers
Cheers
#5306
Hey I got a fw-05t upgraded to a bastard R/RR and I want to replace my stock shocks with the 3-Racing ones. Are they any good? They cost half of what kyosho asks for their tuned ones...
#5307
#5308
Exhausts for 05 series
Gday everyone I have been running the cheaper JPL pipes on my 05 and have gone through a few. What I wanted to know is are the skyline and the hard pipes that much stronger. I dont mind spending the extra money if I dont have to replace the damn pipe every time I take a hit.
Yeah I know need to stay out of the way so I dont get hit but unavoidable sometimes. Are all the other more expensive pipes stronger then the JPL like the Novarossi etc or are the Hard and the Skyline the pick of the bunch.
#5309
#5310
Originally Posted by roadrage
the skyline is alot stronger and will produce more power.
