Kyosho FW-05R
#4561
Hi Nimo,
can you give me some tipps what inserts to use with rubber tyres? I am currently using Speedmind Standard-profile inserts medium but i am looking for an insert that gives more support to the sides of the tyre. Thank you!
Regards,
Robert
Regards,
Robert
#4562
I've been using Echo inserts for the last few years, I'm using the soft (yellow) inserts but some use the medium (orange) inserts.
Echo J4430S (High Traction) or if this gives a little too much front then use (in the front only) J4432S (High Pressure)
(S=Soft, if you prefer medium then change last letter to M)
Do not use the J4429 or J4431 inserts, they are for Electric use and give too much air gap for IC use.
High pressure puts most of the load on the centre of the tyre
High Traction puts more pressure to the outer edges of the tyre
#4563
Hi Nimo!
Thank you for the reply. I already thought about using Echo inserts but was wondering if the 5,6mm were not to thick. Unluckily, i am not able to find your suggestions on the Powers website: http://www.powers-international.com/...cho/molded.htm
Can you give me another hint?
Regards,
Robert
Regards,
Robert
#4564
Originally posted by Robert-FW05
Hi Nimo!
Regards,
Robert
Hi Nimo!
Regards,
Robert
I use ING 0.8 24mm Wheels, Echo inserts and Sorex tyres.
#4565
hi
does anyone know if rossi make a pipe / header to suit the fw-o5, and what starter box is best to use... thanks....
#4567
thanks, does it work well with the rossi s3? whats the best starter box to use with the fw-05?
#4568
Moderator
Well this coming weekend is the opening of the Nitro onroad season here in the north! (WI) I placed a last minute order for parts from RC-Union, to hopefully make it here if not next weekend the weekend after. Including that quick change center bulkhead from 3R, Kyosho lightened clutch, and Gray shoe, and some other spare parts.
One thing I noticed is that Tower Hobbies seems to have dropped all Kyosho cars from their shop, everything including the RRR and 05R are listed as discontinued and all of the parts for them are listed as the same. Sort of a bummer
Also sorta sucks that many people from this thread jumped ship to the RRR WC hehe. Figures that once I get a car everyone moves on to a different one hehe.
Also for those looking for good prices on foams... THS racing has 8$ per pair foams. I have 50$ in goodies coming from them this week
#4569
RD Logics 1 piece pipe
hello
just wanted to know if anyone here uses or has used the rd logics 1 piece pipe ?
same as the one josh cyrul used on his fw
what type of track would this pipe be most suitable for ?
any pros/cons ??
thanks heaps
You guys have been great!
John
any pros/cons ??
thanks heaps
John
#4570
Re: RD Logics 1 piece pipe
Originally posted by mrgsr
hello
any pros/cons ??
thanks heaps
John
hello
any pros/cons ??
thanks heaps
John
I had an original one, it was supposed to be race legal (5.2mm) but was actually 5.9mm, and it was totally pants in the performance departpent.
The later version has been rated here by others.
I found Kyosho's own pipe (VSW024) to be good in performance and fuel economy, and it has also been the strongest of all the pipes I've tried, but it's not cheap.
#4571
skyline pipe stinger diameter
hello
to the guys using the skyline vr12s pipe...
i just received my vr12s pipe for my fw05r and i measured the internal stinger ... to my surprise its only 4.55mm
shouldnt this be 5.2mm ?
I wonder how this pipe will perform compare dto my rd logics pipe
#4572
Super Moderator
Re: skyline pipe stinger diameter
hello
hello
#4574
it just says
legal race pipe for fw-05r
it just says
