Like Tree4Likes
Kyosho FW-05R
Old 03-06-2005, 07:47 PM
  #4291
jeffreylin's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Pipe
Originally posted by Marcos.J
are you running one-way or diff in the front?
One way.
jeffreylin is offline
Old 03-06-2005, 08:55 PM
  #4292
Trader Rating: 15 (94%+)
Default weird track width
hey team
i managed to borrow a mates hudy setup board to check all the settings on my fw-05r foam tyre hop up edition.
what i noticed was that the rear track width from outside tyre edge to tyre edge was only 185mm ??
The front track width was 198mm
This is quite weird as i built the car exactly as it says in the manual using vernier calippers to get the exact measurements.
I doubt this is normal as the car should be a pure 200mm wide chassis
What i have done now is put on rrr front hubs and adjusted the front track to 195mm, in the rear i adjusted it to be 200mm but the dog bones were really loose and falling out, so i put in rrr rear dogbones and this has solve dthat problem.
thanks
john
mrgsr is offline
Old 03-06-2005, 09:30 PM
  #4293
Trader Rating: 37 (100%+)
Default Re: Re: Re: Re: Pipe
Originally posted by jeffreylin
aloha wayne. the skyline pipe is that good. people have been telling me to try it and i thought why change when it ain't broke. well am i glad i tried. i am not sponsored by anyone so you know this is no hype. i have not tried the rd turbo 2 so can't comment but their first version was one of the reason why people thought this car is undergeared.
the 1 and 2 degree front RRR wheel hub adds caster. i have them but have not tried them yet as the car is running so good as it is.
hey jeff and Marcos.J, thanks for the input. i just ordered the pipe today.
Buggy Master is offline
Old 03-07-2005, 05:26 AM
  #4294
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Pipe
One way.
thanks
Marcos.J is offline
Old 03-07-2005, 08:46 AM
  #4295
uaerc's Avatar
Hi guys
does Skyline racing take payments from abroad or only USA ?
uaerc is offline
Old 03-07-2005, 08:47 AM
  #4296
Super Moderator
Marcos.J's Avatar
Originally posted by uaerc
Hi guys
Ken accepts paypal also
Marcos.J is offline
Old 03-07-2005, 08:48 AM
  #4297
Super Moderator
Marcos.J's Avatar
Default Re: Re: Springs
Originally posted by InitialD
Not all Uncle Cow... Black front springs are harder than Gold rears. A list of hardness from gold, black and silver springs are as follows...
Front
VZ072-2517 Gold = 863 g/mm (48.3 pounds / inch)
VZ072-3017 Black = 719 g/mm (40.3 pounds / inch)
VZ072-3517 Silver = 617 g/mm (34.6 pounds / inch)
Rear
VZ073-3516 Gold = 493 g/mm (27.6 pounds / inch)
VZ073-4016 Gold = 432 g/mm (24.2 pounds / inch)
VZ073-4516 Gold = 384 g/mm (21.5 pounds / inch)
Thanks "D" for the springs weight rate!
Marcos.J is offline
Old 03-07-2005, 03:54 PM
  #4298
Front
Rear
Guys, I just bought the Kyosho rear spring set. It just says Silver = Hard, Gold = Medium and Bronze =soft The reading above for front springs is silver = 617g/mm. Does this mean that the lower the g/mm the harder the springs?
cow buster is offline
Old 03-07-2005, 05:55 PM
  #4299
BundyMan's Avatar
In simple terms, if there is a weight of 617 grams sitting on the spring, it will be compressed by 1mm (if I am not mistaken). Looking at the figures, Silver spring is the softest (for the front).
BundyMan is offline
Old 03-07-2005, 06:08 PM
  #4300
esham's Avatar
esham is offline
Old 03-07-2005, 06:17 PM
  #4301
esham's Avatar
Abit correction on D spring colour for rear
Rear Spring (4.5x1.6) Silver (Soft) No.VZ073-4516
Rear Spring (4.0x1.6) Black (Medium) No.VZ073-4016
Rear Spring (3.5x1.6) Gold (Hard) No.VZ073-3516
Check this out..
Kyosho spring
esham is offline
  #4302
InitialD's Avatar
Default Re: Re: Re: Springs
What's the part number for this Kyosho rear spring set?
InitialD is offline
Old 03-07-2005, 06:24 PM
  #4303
InitialD's Avatar
Alamak... Just realised my mistake. Thanks for the correction. I think I posted too early in the morning before coffee !
InitialD is offline
Old 03-07-2005, 06:30 PM
  #4304
esham's Avatar
Your hand is too fast. And it is with Cow buster colour and hardness spring combination - Silver -hard?? Yes he need to let us know the part number.
esham is offline
Old 03-07-2005, 07:58 PM
  #4305
Moderator
Clegg's Avatar
I bit the bullet today and bought the shimo main chassis for my car, after seeing how the stock one I had was warped nicely.
I also bought the five star lightened 2nd speed shoe holder. that and the hardened al. center shaft will remove a ton of rotational mass from that area I think.
Also ordered 2 sets of a arms for the front/back and 2 sets of hubs for the front and back so in the season I dont need to place HK orders for replacement parts hehe.
Clegg is offline
