Kyosho FW-05R
#2746
Originally posted by cvccsi
KidDynomite...
I think trimming down the rear lower arm is a must when using the RRR upright... I was getting a rear width of 210mm+..
KidDynomite...
That's a little to wide for me.
#2747
ha ha ha ha... that was what I was thinking when I measured it last night.
Even with the Mugen Rear Upright, the rear width is over 200mm.
#2748
Re: WIDER
Originally posted by Slotmachine
Remember Kidynomite, wider means less grip!
#2749
definitely some trimming job is needed to get the correct length or like Atomic said, use the shorter front wheel axle. With the front wheel axle, you will be a bit over 200mm without any trimming.
#2750
Got some RRR front hubs / rear hubs / rear arms to fit this weekend and test.
It would have been done a few days ago but I've had PC problems this week, The monitor finally gave in then I managed to snap off the sound output socket from the sound card.
PC back running again with sound and LCD monitor, so now to spend time on the 05.
#2751
Nimo, let us know your finidings.
#2752
Ron,
If worse comes to worse I have the front end conversion on my car. I can't make it to Nats anymore due to a big work project I have to work on. So, my car will be unused. I've only ran it twice this summer and the Kawahara front end parts have not suffered any crashes.
Enough folks in Toledo know how to reach me (including Josh) so if you find you need it give me a call and you can use it. I live about 40 minutes away from the track.
-Rich
-Rich
Originally posted by ATOMIC
Does anyone have the Kawahara front end conversion in the US? I would like to buy a spare for the Nats , new or used.
#2753
Another new guy question!
Hey guys!
So i keep reading about this Kawahara parts and such. I am assuming these are the best hop-up parts for the FW-05. If so, which do you recommend. Mine arrives Monday and I would like to order stuff for the car by Saturday.
Any suggestions send them my way...
jbro
jbro
#2754
37t ring gears
Been looking for these gears and they only come up on the web for the Tamiya.
Which ring gears do you guys suggest for the Kyosho?
JBRO
JBRO
#2755
Re: 37t ring gears
JBRO
JBRO
#2756
Jeffreylin- wed or thursday next week, that will be shipped directly to the track. I really would like to find kf-1044 which is the suspension pin holder. If I could find those I would buy a couple.
KO - Sorry , I did not mean to make you use that little brain of yours. LOL You going to the gas nats?
Sent you a PM on the front conversion and KF-1044.
#2757
Re: Another new guy question!
Hey guys!
jbro
Hey guys!
jbro
The 37T gears are a must.
#2758
Thanks for that. I couldn't find them. I was thinking of getting the tront stay and the rear stay along with front and rear shock mounts (FW05-004 and FW05-022). Worth the cost?
JBRO
JBRO
#2759
Re: Thanks
JBRO
JBRO
37t ring gears
Brake disk
Delrin pivot ball cups
bearings for the servo saver
Thats about it!
That didnt stop me getting the....
MTX-3 rear hubs
VoneRR rear camber links
3racing centre section
Kawahara centre conversion
Stepped bearings for the steering arm
UJ's front and rear
etc......
#2760
Re: Re: Thanks
Originally posted by ziggy12345
Only get whats needed.
37t ring gears
Brake disk
Thats about it!
MTX-3 rear hubs
UJ's front and rear
etc......
37t ring gears
Brake disk
Thats about it!
MTX-3 rear hubs
UJ's front and rear
etc......
