HPI R40 Nitro Car Forum
#1006
Originally posted by NitroLeadFinger
Wow, did the R40 magicly turn into a Serpent 710 for some guys? Ok - I couldn't resist.. After reading this I got the feeling these message boards are mostly dominated by "bench" racers, and not actual RC car drivers? Anywho, I hope others find some comedic value as I did..
Thanks again for the helpful answers
WOW! you must be a die hard hpi fan! actually its just an observation. only had 2 races under my fully hopped up ntc3 and i have never even opened my r40 and i'm already getting the serpent. anyway, that doesn't mean i'm not interested in the r40 anymore... hey i found your post didn't I? now come to think of it... i AM a bench racer!!! More power to the r40 drivers!!! i hope a lot of people can support this thread like nitroleadfinger so we can learn more how to squeeze every ounce of performance from the car... even for a newbie like me
#1007
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
when is that stuff being released? cuz i dont like the look of the R40's stock diff
I hope these aluminum parts are not a trend toward making this car a hop up queen........Instead of (heavier)aluminum,I want to see things like lightweight parts for performance..the chassis is a good start,hopefully that gear diif uses lightweight gears,..things like that..
#1008
NitroLeadFinger,
I ended up setting my R40 up just like my MTX2 and MTX3. To me, since the car is so similar to the Mugens, I took a shot at it to see if it would work. I hit the mark. Between the 3 cars, I cannot really tell much difference in handling. If you had run other cars, use your best handling setup as a starter point and fine tune it from there.
#1010
Thanks for the tip jlock... Oddly I found that the 'derived setup' I measured was quite simular to the serpent 705 oddly enough, or I should say it was much closer to the 705 setup than what the setups HPI has listed on the website.. I will try and hunt down the MTX info and see what meshes.. I am not really trying to hit the perfect setup, just a baseline I can work from.. I most liekly will prescribe my own 'frankenstein' setup! thanks again!
#1011
#1012
I would like to know how you guys are getting the blank set-up sheet from the HPI web site. When I try, I get a error message saying I need some kind of a Japanese language conversion program. Anyone know what that is and where I can get it?
#1013
#1014
#1015
Language pack
http://www.adobe.com/products/acroba...nfontpack.html
Hara's setup sheet (to test the font pack!)
www.hpiracing.co.jp/contents/ setup/pdf/ha030810roar.pdf
#1016
Ok guys,
#1017
OK..this is it..
HPI needs to ADDRESS the damn ISSUES with this car..
CHANGE THE FUCKING PLASTIC.
ADD A FUCKING SHOCK BLADDER
GIVE US CF TOWERS AS STANDARD (cast aluminum SUCKS....)
BEEF UP THE DRIVELINE COMPONENTS.. (rubber belts.. )
#1018
Hey can someone clarify something for me... Is it safe to assume that the "rebound stop" is the same as an up-stop, and the 'bump stop' is the same as a downstop? Just want to get the terminology down.. This whole stop thing in general is a bit new to me, so I have been a bit too fascinated with the dynamics.
For example (using the rear for example) when I set my rebound (when the suspension is full compress) I get about 7.5mm of daylight between the arm and the surface, with that the car has about 2mm of clearance between the chassis and ground, using a 57mm tire diameter. What seems puzzling is the HPI team drivers (going off their posted setup sheets) set the rebound stop at 3.5-4mm, which if I calculate correctly would mean the suspension would bottom out with about 6mm between the chassis and the ground. Yet they indicate ground clearance is 5mm rear, my math must be wrong, or I have my bump stops, rebound stops confused. I don't think it is physicly possible to setup the rear suspension with -1mm of travel!
#1019
Originally posted by tranced
OK..this is it..
OK..this is it..
#1020
Regional Moderator
OK..this is it..
OK..this is it..
