HPI R40 Nitro Car Forum
#9991
brett, were you using a modified 12TZ or a standard one?
#9992
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
hew brett and AMG.....how are those 05's running.....and do you (still) see a big difference between the new and old cars?...it's almost nitro season here....and I plan a full summer of racing with the r40....
#9993
Hello all,
My first nitro race of this season is sunday and I am having a little trouble. The car is lagging on take off for some reason, It's not engaging first gear until I get deep into the rev range, it feels like it's in neutral. Does anyone have any advice?
#9994
Originally Posted by vulso
Hello all,
they are notorious for tightening themselves up... some people find a good setting and then use loctite on it..
#9995
how loose should I go? I put a mugen spring in there to try and help and it made it worse. The instruction setup just leads me to more trouble!
#9996
#9997
sounds like the mugen spring is going to make it engage harder..
#9998
help
hi can anybody help i cant seem to get my rc started its brand new and has not yet been broken in im new to all this HELP thanks all/is it possible to tell is the glow start is working rite or if ive just got a faulty 1
#9999
Thanks Onnetz. This is the wierd part, I have done what you suggested and adjusted it to the point where it wouldn't adjust anymore and it didn't solve the problem? This is the situation I'm in now?
Originally Posted by onnetz
there is no set setting.. I always adjusted mine in between runs. you can adjust it through the clutch bell.... I usually go 1/4 a turn then try it..... you should notice a difference right away..
Gotta love the r40 clutch.
Try scoring the CB and clutch pad with sand paper. That should help.
how much of a gap do you have?
Tell me about it! Everything else about the car works really well.
might be time to replace the shoes and or the disc.. you could try adding another shim to make up for whats worn away..
Onnetz, my gap is set per instuctions and is real close to it. I am using extra shims to get it though. But, there is some play side to side on the clutch? I have new parts coming for the clutch. I tried to set the clutch according to the instructions but I'm just running out of adjustments to get it to work right. Would pics help?
also could you notice a difference at all when you loosened the clutch nut?
Bring the gap as close together as possible. It should basically barely move back and forth.
But yeah you gotta score that CB with sandpaper. Its probably glazed now along with the clutch pad. This will bring them back to there original grabbiness.
