HPI R40 Nitro Car Forum >
Old 05-05-2005, 10:27 PM
  #6436
KLANDERMAN's Avatar
HARK did you get the clip?
KLANDERMAN is offline
Old 05-05-2005, 10:55 PM
  #6437
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Yep, I got it. Seems pretty quick for the .15FE. Reminds me of the old days.
HarKonnenD is offline
  #6438
Rapid Roy's Avatar
Originally posted by HarKonnenD
lol.
Klander- I ran the Rody V12 and it is unbelievable!!! .
The bottom end of the MT12 in no way comes close to this engine. A good firm tap on the throttle sends it 10ft+ easily. What I also like about it, is that it's not even maximum power yet and it is flat out fast! I still need to get diff fluid for the rear. What diff fluid are you and other guys running for the rear? Did you install the rear axle instead?
I'm using 30000 with the 4 gears in the rear. I only filled the diff 1/2 full though.
Rapid Roy is offline
Old 05-05-2005, 10:56 PM
  #6439
HarKonnenD's Avatar
Sounds good. I'll pick up the one way and try the 4 gear mod with 30k fuel. Maybe those Savage gears will do the trick. Not gonna buy a whole new diff.
Old 05-06-2005, 06:16 AM
  #6440
Originally posted by Benzoil
I misunderstood your post about 50 pgs back then: i will stick the O-spring back on. what about the first shim behind the engine? Is this absolutely necessary on my nsr12?
If you are talking about the black washer that goes before the collet, then yes it does have to on to get proper engagement. Then use 3-4 shims staggered. So sliver bronze sliver or all four or whatever. "Sabotuer" on another board said that the Novas are the same and he has silver bronze silver. So try that.
performula is offline
Old 05-06-2005, 08:34 AM
  #6441
HarKonnenD's Avatar
YEp. Exactly what I did. I took the black washer from my MT12 an threw it onto the Rody engine. Then, I put the collet on, the clutch assembly, and actually I used ALL of the 6 washers in the pattern silver/bronze/silver/bronze, etc. Clutch bell should move a tiny bit when you tug it outward. Also, the stock setting for the adjuster nut works pretty well with it.
Klander-Heard some feedback on people running the OS .12TZ and it's in close competition with the other modded engines. Probably when it comes out you should get it and try it.
Old 05-06-2005, 08:44 AM
  #6442
KLANDERMAN's Avatar
Sounds nice! I'll probably check it out... Was this the 3 port or 5 port? o you know??? Anyway I shoul probably get the 3 port that way I can race with it...
Old 05-06-2005, 09:44 AM
  #6443
HarKonnenD's Avatar
Well the material is stronger, and it has lots of HP, but it doesn't have the speed of a Novarossi or RB. If its one of them HUGE tracks, Nova or anything else would be a better choice. If it's smaller than the OS would be great.
Old 05-06-2005, 03:48 PM
  #6444
Trader Rating: 20 (100%+)
hey guys, im new to the whole nitro onroad things so i have a question for ya. does anybody have a downloadable setup for a r40 for ohio? i just ran my car for the first time and have no idea where to start. i am used to running offroad so a good starting point would be great. thanks!
Jamie Fredericks is offline
Old 05-06-2005, 03:54 PM
  #6445
onnetz's Avatar
there are a couple setups here...
http://www.hpiracing.com/setups/su-m.htm#r40
onnetz is offline
Old 05-06-2005, 11:50 PM
  #6446
KLANDERMAN's Avatar
here is a pic of the lola body
  #6447
KLANDERMAN's Avatar
here is a pic of the lola body front...
Old 05-07-2005, 12:25 AM
  #6448
onnetz's Avatar
looks really good...
let us know how it handles... should be plenty of downforce.
onnetz is offline
Old 05-07-2005, 12:34 AM
  #6449
KLANDERMAN's Avatar
here is another one from the rear
Old 05-07-2005, 09:03 AM
  #6450
Klanderman,
I do not know if you read my previous post or PM, but what Lola body is that and where did you get it?
I've been E-mailing GasRCCar about the Kawahara Lola body, but never get a response.
