HPI R40 Nitro Car Forum
#3616
I think the posts being high was actually what is supposed to keep the housing off the shoe, it's just not a very good way of doing it. I noticed my latest clutch bell looks a little different too, a little thinner I think.
#3617
I had one post that was rubbing and another that was a bit higher but no rubbing. A few lite taps and the problem was gone.
#3618
Originally posted by treky11
You don't have to dremel the posts. Just take the bell and place on a flat hard surface and hit the post gently with a hammer. they will push back into place.
It seems that on some of the bells the posts are not seated all the way. I had that problem on 1 of my clutch bells too.
Are you saying I should place the FLYWHEEL upside down (posts facing down toward the table or flat surface) and use hammer and tap it a little...?
Thanks....
#3619
Originally posted by Rookie Solara
I am a little confused here.......I was talking about the 4 posts that mount the flyweight and the clutch shoe are being too long or uneven length........and about the clutch BELL, that does not have posts on it...
Thanks....
Thanks....
#3620
That, HPI is missing for the whole setup.........but I am sure HPI will have their answer, but so far, they have no respond on that..
#3622
Originally posted by 20 SMOKE
any one
any one
In my R40, I used Mugen 50,000 up front and Yokomo light (like 5,000) at rear.....and I replace the front oil every 6-8 race days (after the front diff used out like 6-8 race days, it will get loosen up)...
In some tight track, ppl even use the Serpent cleaning gum (just a little) inside the front diff and make it like a LSD at front, it has the effect like the SPOOL (solid front axle) for super fast tight cornering but without the snapped or popped out dogbone problem like on using spool.
#3623
Regional Moderator
I actually use the same setup I used on my old Trinity Reflex.
-25,000wt front
-80wt rear
that may seem really light for the rear, but remember that HPI calls for nothing more than diff grease in the rear. So even 80wt oil is a big change from that.
This setup worked for me on the Reflex and its working now on the R40.
As for reading material on the subject, I don't know...
-25,000wt front
-80wt rear
#3624
Okay guys. I've been gosting this thread since it started and I finally got me a pair of used r40's. One all hopped up, the other pretty much stock. With enough extra parts to make my head spin. I'm going to go through the cars with a fine tooth comb so I'm familiar with them and get to racing.
#3626
This is probably the first of many questions.
I have 2 spare stock purple chassies. They both seem to have a slight bend in them towards the front right about where the front diff is. One is bent more then the other.
I seem to remember this being a problem with some of the earlier kits. Can anyone shed some light on this for me. I tried reading from the start of the thread, but didn't have enough time. They have never even been installed.
#3627
#3628
Thanks for the reply. I was thinking the same thing. Just kept having the thought that I had seen it posted here before. I guess its no biggie. They are spares anyway.
#3629
solid diff
does anyone know how to make the front diff into solid diff? I was thinking about putting j&b weld, in the front diff, to make it a solid.
also, does anyone know where I can find the manual for the HPI Rear Solid Axle Purple R40 pn# 75060. I dont really see how it all works together, with the out drives.
thanks jason
thanks jason
#3630
You would be better served by purchasing the front one-way diff...otherwise, you will suffer terrible handling in off-power corners because both wheels will try to spin at the same rate which I believe would induce massive understeer.
