Old 05-23-2010, 07:03 AM   #2101
kai888's Avatar
Trader Rating: 17 (100%+)
is that the bearing that has two pieces one on each side that comes apart?
i haven't had a chance to take it apart yet and i'm just looking in my manual
kai888 is offline   Reply With Quote
Old 05-23-2010, 08:35 AM   #2102
MikaR's Avatar
The 2-speed transmission..not the centax clutch.
2-speed has the 2 large gears and inside 1st gear there's a one-way bearing holder that holds the gear on the axle. Remove the screw and the cap so the bearing comes out along with gear. Keep it there, don't take remove the bearing from the holder, but clean it carefully and re-lube using WD40. It will work then.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 05-23-2010, 09:00 AM   #2103
kai888's Avatar
great, thanks for the info.
Old 05-23-2010, 10:22 AM   #2104
MikaR's Avatar
You're welcome. Should do the trick. If not, pls let us know ok. Cheers
Old 05-24-2010, 08:52 AM   #2105
how many degree steering throw are you guys getting..
i just noticed something.. when the steering is full locked.. the turnbuckle is hitting againest the inner bulkhead preventing it from going any further.. also the opposite side, the inner wheel is hitting the shock ending..
i figured out you could dremel the inner bulkhead down where the turnbuckle hit and also dremel the ball endings down abit to give you a better steering throw..
would this possibly help the RRR steering? especially on tight, small tracks with alot of hairpins..
LiL_JaSoN is offline   Reply With Quote
Old 05-24-2010, 11:28 AM   #2106
MikaR's Avatar
I checked my car.. the wheel does not come even close to touch any parts when maximum in their position left/right.. not turnbuckles or anything else. There several millimeters of space in between. Servo horn cannot turn more .. it is done as advised in the manual.
Are you sure you are using wheels meant for this car.. 0 degree offset. Not too narrow or anything?
Old 05-24-2010, 09:21 PM   #2107
thats weird.. im running matrix wheels, front is running 199mm i think.. however i might change it to 200mm as that would give me a lil more steering throw?
im also running the old ackerman link as i have a front diff going in
here are some pics
and here is steering at full lock. as you can see the right wheel is hitting againest the shock ball end... I think kai888 had this problem aswell
Old 05-24-2010, 10:12 PM   #2108
This is normal. Just turn down your epa a little. If you use ackerman 11 or 12 this will not happen. ackerman 10 gives equal throw side to side.
Ackerman is the difference between the inside and outside tire throw.
10 ackerman - tires turns equal
11 ackerman - inside tire turns more
12 ackerman - inside turn even more then 11 ackerman
Hope that makes sense,
Joe
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 05-24-2010, 10:59 PM   #2109
kai888's Avatar
yeah i had the same problem, so i ended up just adjusting the epa on my transmitter. Is akerman the bit where the two turning rods snap onto?
Old 05-24-2010, 11:32 PM   #2110
prettysure im running ackerman 11.
Old 05-25-2010, 09:25 AM   #2111
MikaR's Avatar
Old 05-25-2010, 07:39 PM   #2112
kai888's Avatar
hey guys, does the wing make a difference?
my car doesn't have a wing on it and i've got the stratus shell and some guy at the track was telling me that its because i don't have a wing that my car is oversteering around corners?
initially i just put it down to my shit driving
Old 05-25-2010, 07:41 PM   #2113
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I cannot emphasize how much the wing affects handling and down force.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-25-2010, 07:52 PM   #2114
kai888's Avatar
is there a trade off between straight line speed and having a wing?
Old 05-25-2010, 08:10 PM   #2115
KHoff7's Avatar
The trade off is you car will handle horrible. There will be next to zero in speed difference.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
