Is this normal? >
Is this normal?
Is this normal?
Old 03-01-2008, 01:51 PM
FavreRunner's Avatar
Default Is this normal?
I have a question about the 4wd on my HPI RS4 18SS+. When I lift it off the ground and gas it, only the front wheels spin. When it kicks into 2nd the rears start spinning. This isnt normal is it? Im a noob.
FavreRunner is offline
Old 03-01-2008, 03:01 PM
Check your rear diff.
SMOKESHOW86 is offline
Old 03-01-2008, 03:20 PM
Okay. Thanks. Should I take it apart to see the gears? Is this common problem? Ive only ran this car 4 times in a parking lot.
Old 03-01-2008, 10:58 PM
Roelof's Avatar
Also check the cups at the end of the the middle schaft, they can come loose
Roelof is offline
Old 03-02-2008, 07:34 AM
Looks like the center diff was the problem. Tha set screw that locks the cup joint was loose. Thanks for the tips.
Old 03-03-2008, 01:34 AM
itchy b's Avatar
Always make sure that you check the set screws and all the screws on your car for that matter.
itchy b is offline
