Kyosho Evolva M3 >
Kyosho Evolva M3
Kyosho Evolva M3
Old 11-18-2010, 07:32 AM
  #811
Trader Rating: 41 (100%+)
Originally Posted by HoboShop
None that I have heard of. I would guess they would just put out a upgrade kit !!! The car is ready to go as it is just by all the kyosho factory hopups. That's what I did. The car is super fast and light.
Did you do anything to lighten your car? My car weighs in at 2600 grams.
davidl is offline
Old 11-18-2010, 12:53 PM
  #812
Yes I did the ti pillow balls all the way around and ybslow ti midshaft along with a life receiver pack made my car way under weight!!!! But the car out of the box with gear installed was right at the 2552 limit. The m3 is the lightest 8 scale car out of the box it was much lighter than my mrx4x and 966. You also can try ti upper screws they will also drop your weight down. I tried them but didn't like them because there made with a softer material and the stip way to easy so I took them out. Life battery are just as light as there lipo counterparts but are much more safe and life battery don't require you to use a voltage regulator. I hope this helps
HoboShop is offline
Old 11-19-2010, 06:02 AM
  #813
Thanks for your input. I am using a 5 cell NMHd battery. By the way, the minumum weight is 2525 grams.
davidl is offline
Old 11-28-2010, 11:15 AM
  #814
Default m3
hey guys
where can i purchase the cheapest m3 online?
is amainhobbies the cheapest??
many thanks
kurtcash is offline
Old 11-28-2010, 02:38 PM
  #815
occ
Trader Rating: 16 (100%+)
Originally Posted by kurtcash
hey guys
many thanks
Yes, amain is the place to buy from.
occ is offline
Old 11-30-2010, 08:56 AM
  #816
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Anyone know if they make an aluminum brake lever for the M3? I know kyosho makes one for the v one rrr but I don't think its compatible. Thanks
hotdognobun is offline
Old 11-30-2010, 02:28 PM
  #817
occ
Kyosho don't make one for the M3. Maybe some other brand does but I have never seen one.
occ is offline
Old 11-30-2010, 02:31 PM
  #818
thx
Old 11-30-2010, 04:23 PM
  #819
Speedypeterb's Avatar
Default evolva 2005
why are the worlds drivers running the 2005 and not the m3
Speedypeterb is offline
Old 11-30-2010, 04:31 PM
  #820
hey guys
many thanks
No way. If I am going to say money, I would get the M3 Evo upgraded kit:
http://www.rc-toro.com/product_info....fe600644653c87
And then pick up an used Evolva
silverM3 is offline
Old 11-30-2010, 05:36 PM
  #821
occ
I noticed that too. I'm thinking the race register program doesn't have M3 as an option to choose from. Pretty sure they won't be running the old Evolva 2005.
Who knows, maybe he wants a whole new car, not the upgrade kit.
occ is offline
Old 12-02-2010, 12:44 AM
  #822
Wanabrc's Avatar
Trader Rating: 70 (100%+)
No, I believe Collari did infact win the last Worlds with an "old school" Evolva. I figure he's got that model dialed in setup and crewpit wise. He has a winning formula so as the age old adage goes "If it ain't broke, don't fix it".
Wanabrc is offline
Old 12-02-2010, 02:08 AM
  #823
occ
No, that is not correct. He used the M3 Evo with a few modifications. This is a pic of his car at the 2009 Worlds.
occ is offline
Old 12-02-2010, 06:33 AM
  #824
The 2005 evolva was and still is a great car, however the m3 evo is faster than the 2005, and the m3. I can explain it but the m3 evo just has more overall on&off power steering and is just dialed in. Out of the box. Plus the inner gear ratio gives the car more rip everywhere. If you have the m3 go out and by the converstion and you will see. I think it is the best handleing 8 scale car on the market. Some car may come with more hopups out of the box but they are not as fast. The kyosho has the best internal gear ratio of all the 8 scale cars.
HoboShop is offline
Old 12-03-2010, 12:01 AM
  #825
Wanabrc's Avatar
I take it all back. I thought the IFMAR Worlds report had stated that Collari was using the Older Evolva. I must have missread it somehow.
Wanabrc is offline
