Kyosho Evolva M3 >
Kyosho Evolva M3
Kyosho Evolva M3
Old 01-31-2008, 09:49 PM
  #226
occ
Trader Rating: 16 (100%+)
Originally Posted by bsmooth
Thank you.
Thats ok.
Btw: Has anyone purchased the optional side plates, battery plate & the front chassis plate yet? Also the other parts to laydown the throttle servo?
occ is offline
Old 02-01-2008, 05:29 AM
  #227
Haven't attempted to do a full assembly on the car yet as I've been working on detail parts but it looked like the parts were there to do the laydown throttle servo mount. I scanned the exploded view and the parts list the other day and I'll attempt to attach them.
File Type: pdf
File Type: pdf
File Type: pdf
Rick Davis is offline
Old 02-01-2008, 05:30 AM
  #228
Hey it worked - Rich will be so proud
Old 02-01-2008, 05:55 AM
  #229
Rick,
I can't wait to get the essential parts. In fact, Mark won't see my kit until I get those parts!
PS;
You think you can make a light weight Alu. brake disk?
I'm hoping the APS Brake fits...
NitroHead is offline
Old 02-01-2008, 09:34 AM
  #230
The brass batterie tray is 54 grams.
nitrodude is offline
Old 02-01-2008, 09:40 AM
  #231
Paulie Bee's Avatar
Default M3 Spare Parts
Anyone heard when spare parts that were ordered to CA will be going out?
Paulie Bee is offline
Old 02-01-2008, 09:50 AM
  #232
I think Team Kamikaze has them allready, I havent asked him, but he was told he should have them this week.
The car IS light. With a brass tray, pipe, body, engine and 5 cell batterie, minus the clutch, the car is 248 grams under legal weight.
Old 02-01-2008, 10:15 AM
  #233
Trader Rating: 28 (100%+)
Parts are supposed to be in at Kyosho today. That is info I was given on Wednesday.
Scott Fisher is offline
Old 02-01-2008, 03:54 PM
  #234
yup
Old 02-01-2008, 06:42 PM
  #235
Paulie Bee's Avatar
Default M3s in Stock at Brooklyn Hobbies 718-951-2500
Brooklyn Hobbies has plenty of M3 Kits in Stock if anyone is looking for them 718-951-2500 call Richie
Old 02-02-2008, 09:14 AM
  #236
bsmooth's Avatar
Trader Rating: 18 (100%+)
Could any of you explain what the different rear suspension holders do?
Also, would this be considered a gross adjustment or a finite adjustment.
I appreciate any 'tutorial' on this.
Thank you,
Steve
bsmooth is offline
Old 02-02-2008, 10:26 AM
  #237
rocca30's Avatar
i made one for chris toso out of silver and it weight 62.5 grams. also looks great.
rocca30 is offline
Old 02-03-2008, 10:35 AM
  #238
YBSLOW's Avatar
Default M3 Brass Battery tray
YBSLOW is offline
Old 02-03-2008, 06:13 PM
  #239
Originally Posted by Jim Adkins
Antone,
The kit does not come with an aluminum mid shaft mount.
Jim Adkins
Hmm, the Kyosho website says it comes with this. It also says the car has 3 lengths of upper rear arms but in the set up sheets I looked at it doesn't show anything like 3 different arms. Can somebody explain this to me please?
UPSguy is offline
Old 02-03-2008, 08:55 PM
  #240
The upper rear arm is made up of a base rectangular shaped piece and an added pivot ball mount (coupled by a 4mm tie rod to give adjustability) which is included in three lengths. The shortest is used with the outboard pin position, the middle length is used with the inner pin position and the longest goes with the "A" lower block set which replicates the geometry of the 03 car, the setup sheet seems to ignore the latter option. Someone asked about the laydown servo parts - had a moment to look today and the plastic parts are included in the kit but all the fasteners, the pivot post and the ball bearings are not included, if you've been doing this game for a while most of the missing bits are probably kicking around your spares box already.
