GT class--buggy-based on road!
#5671
Mhhhhh ... i can be wrong but under my experience, if the guys are using "the louder pipes available" even with INS boxes the benefit will not be there, is the combination of EFRA/IFMAR pipes + INS's in Europe that do the job.
Anyway ... those videos have AMAZING SOUND hehehehe ...
cya !
Pato
cya !
Pato
Have you ever replaced the factory stock air cleaner/filter from a real 1:1 car with a free flowing aftermarket unit? Did you hear a difference in the exhaust tone on your car?
This is not any different with our toy cars. The INS Box will reduce the intake sound and help to reduce the overall exhaust note of the car. Physics is Physics, it can’t be intelligently argued against.
Any slight reduction in overall noise levels of the “GT Open” class might be a good thing for this specific race we’re talking about; for the reasons I’ve stated before about the event location and the audio dynamics of the facility in question.
So please Pato, try to understand that we’re only talking about maybe using the INS in the “GT Open Class” at the Ipanema US GT event at this specific venue only.
The other alternative is putting restrictions on actual exhausts like ROAR, EFRA or IFMAR does and I personally don’t like that type of philosophy for our US GT racing event, ok.
Thanks for your input, experience and understanding of North American style of GT racing.
#5672
I know you are talking about Jeff no problem ... i was just pointing out my personal perspective.
I do race offroad more than onroad and downhere we race under IFMAR rulebook (FAMAR BLOCK) so im in the loop on sanctioned pipes and in onroad with INS BOXES and stuff ... is just that for a hell of a fun class as GT, i would not even think on adding those restrictions. I dont know if my pipes are not so loud, but already tested INS on my GT and i cant see much difference in sound, 1:1 carb throats are way different in sound v/s rc ones,
regards
Pato
regards
Pato
Pato,
#5675
#5677
After a little observation
after thought of hearing about the boxes, i came up with 2 observations id like to share?
<1> Ins boxes in 1/8 onroad, the motors are sticking thru body therefore, the motor gets ampule amounts of air flow, inside the body when i put on a ins box, didnt look to promising,as in 1/8 onroad AND touring the motors are configured differently,sideways so the air can direct right ontop motor head and the ins box is next to it, NOT in front blocking air passage. but with the gt, the air filters are head on with any possible air flow.I think it might cause alot of grief w/overheating issues!
<2> dont you think the large bodies of the gt class by itself work as a ins box? if u think about it, the motor is "buried" in there, and the body is doing same purpose, im just more concerned with not getting proper airflow over head of motor, ESPECIALLY the guys <like me> who run .21 on road motors with the small heads...
i will take a pic tomorrow and show you what i mean if anyone doesn't understand with what im saying here.
food for thought
food for thought
#5678
Pato,
The Venturi effect is the reduction in fluid pressure that results when a fluid flows through a constricted section of pipe. The Venturi effect is named after Giovanni Battista Venturi (1746–1822), an Italian physicist. Carbs work because of his understanding of physics and his genius.
At the core of all carbs, they are all the same and react the same regardless of their size. It doesn’t matter if it’s a lawn mower, a 454ci Chevy or a .21 Sirio nitro engine; if they have a carb, they have venturi and all of them are governed by his proven & undisputable facts of physics.
#5679
food for thought
food for thought
Now that makes 100% sense.
Nevermind the INS, didn't think about the reduction in air flow to the head fins.
Bring on the noise!
#5681
#5682
food for thought
food for thought
Sedans run with them without any problems and those bodies leave hardly any room to breathe. Me personally I will always run one.
#5683
I think Tonny has a valid point because even most 200mm cars have engines mounted sideways and the INS would be on the side of the cooling head. In a GT car the INS would be in front blocking the air flow to the head.
The only way it could work would be if the INS were set up like an off-road air filter with a plastic or rubber extender to move it out of the way; maybe.
#5684
yes, like stated above, the sedans have a sideways configured motor, i will take a pic of my novarossi on road .21 motor AND ins box, front view, and post, theres simply No way it can work....unless like jspeed staed a offset boot to move box away, those boxes are as big as the .21 on road heads...LOL....
if it really is a issue, u can rule out noisy 2 chamber peipes, like the 86, and make all motors .21...thats should do it, between the body muffling<like a ins box> and running the quieter pipes, like a novarossi 2052<sausage pipe> i have one, its going be a quiet killer.....theres ways around, i think just starting w/keeping the class to .21's is a start, if it were to become a problem, than we can move into approved pipes if need be...my $.02
p.s. its Tommy :^)
p.s. its Tommy :^)
#5685
For those looking for an affordable engine, pipe, mani combo. Brand new. http://www.rctech.net/forum/r-c-item...rt-engine.html
