Kyosho VoneR Thread
Also try changing the front roll center
Originally posted by Finken
How?
How?
I haven't been able to find this any where, but I'm thinking of buying a V1RR Evo and we are required to run sedan bodies. Does the kit come with regular body posts or extentions to run sedan bodies? Also I was reading some where about a V1RRR. What would be the difference between it and the Evo?
Should i use the upper or lower mounting hole, inner at the upper suspension link?? The manual says upper, but after vreding here, looks like you are using the lower?
evo
lowest hole on bulk head .highest on outer block......
3 racing has .1mm carbon spacers to place under the front top pivot pin holder..they work killer..see pic for a few ideas.
mike.
wait for the "RRR"...better rear set up..
mike.
i have a problem with understeer out of corners, into corners its great. front:
Black springs,50 wt oil, stiffest bar settings 0 droop
Rear:silver springs, 30 wt oil, kit sway bar 4 m droop
I am considering silver/silver 30/30 oil, looser sway in front and less rear droop. Will that cure my problem??
Anyone have some setup ideas for a good grip, small tecnical track, no bumps.
1 way
are you using a one way ? if not that will give you more drive out of corners.
Yes, i am using oneway.
overstearing
hi there...could do a number of things......softer springs, no front sway bar( done this at a windiy track)..softer tyres front....change body...move body forward...move rear wing forward.....harder rear...take some traction off....lay the rear shockers over...drill one more hole closer to centre of car.......camber link rear highest out side. and lowest inside........
Re: overstearing
over stear..
this will apply to all cars...this was aimed at the v-one rr series.
mike
mike
Re: over stear..
mike
mike
understaer
this is for understearing.......
front body mount & bumper part#VZ007
rear body posts part# VZ083
also this will come in handy,
side stiffener part# VZW002
The v1rrr is a whole new car, very little of the old car parts will be on this kit if any.
The evo kit comes with both body post options
