Kyosho VoneR Thread
Re: Things needed to finish
Originally posted by tazman34685
Questions:
1)is the wt of the plastic gears lighter than the hardened alum pulley setup.
Questions:
2) Floating RR rear body post setup vs the R rear shock set, which is better to work with the evo
3) Lastly who makes/where can I get this new rear sway bar I've seen on the forum "looks like a mugen rear sway bay"
<cue: AMG, Manti?>
tazman34685,
Do you have Tasmanian devils in Florida, too?
I thought we owned the copyright.
In my experiance
Bumpy tracks or Saloon body go with the R type body posts
Smooth track or lola body go with RR type body posts
I just ordered the ally pully set but really they are for looks. The plastic works and doesnt wear the belts as quick and are cheaper to replace
Questions:
Questions:
2/. i find the non-floating body mount works better on EVO (lower CG) as the car is more predictable on both LOLA and sedan.
3/. it is from kawahara. it comes together with the rear bulkhead cross member i.e. price tag is awesome too.
ALLOY GEARS
HI GUYS...I USE TITANIUM GEARS...EXSPECIALLY ON THE FROMT ONE WAY AND MIDDLE PULLEYS....I HAD THEM FOR AGES AND THEY DONT WEAR AND DONT CHEW BELTS.I USE THE TEAM KYOSHO 26 GEAR ALLOY SIDE GEAR...IT WORKS FINE. I FIND YOU MUST CLEAN UP ANY LITTLE BURS ON THE ALUMIN GEARS...DO THIS AND YOU SHOULD HAVE NO PROBLEMS. I USE THE ALU REAR TOWER FOR BUMPY TRACKS..( THE PLASTIC ONE BREAKS WHEN YOU SLIDE OUT INTO A WALL).....I LAY THE REAR SHOCKERS DOWN AS FAR AS I CAN...THIS WILL TAKE A BIT OF TRACKTION OFF THE REAR...I ALSO USE THE KAWAHARA FRONT SHOCKER POST SO I CAN RAISE THE FRONT SHOCKERS....THIS HELPS HEAPS ON ALL TRACKS........I USE LIGHTER OIL...35 FRONT...30 REAR...THIS CAR STEARS LIKE YOU WILL NOT BELIEVE.....ITS THE EVO BY THE WAY....THE SHIMO ONE WAY IS GREAT....
SEE THE PICS
MIKE
SEE THE PICS
MIKE
PIC 2
REAR PULLEY
PIC 3
FRONT
pics4
rear mount
evo
my evo
my new wepeon
FW-05R...FOAM TYRE ,ONE WAY VERSION..NEVER USED.LOOKS VERY PROMISING..THE ONLY THING I DONT LIKE ( THROUGH EXPERIANCE) IS THE ALLOY MAIN GEARS....WONT SET THE CLUTCH TOO HARD AS I RECKON THEYLL STRIP.WAITING ON THE HARDENED ONES TO ARRIVE...WILL KEEP YOU POSTED....
MIKE
MIKE
TAZ just like the sun
Originally posted by Taylor-Racing
tazman34685,
tazman34685,
Re: ALLOY GEARS
SEE THE PICS
MIKE
SEE THE PICS
MIKE
Re: my new wepeon
MIKE
MIKE
mikecatts, what are you using to hold the battery pack in place on the fw-05r,does the item that you are using to hold the battery pack in place use, work well? also how are you liking the fw05r??
thanks J.
fw-05r
im using double sided tape ( good stuff, comes in the kit).and nylon stranded tape, then i shrink wrap to finnish.....
dont know what the car is like.havnt used it...just came back from the vic state champs.great race...got hit in the semmy, on its back..slow marshal and stalled...thats the end of that.the rr-evo is awsome. iwant this to b as good,
mike
mike
Luis
