Kyosho VoneR Thread
#6901
Re: The range of diff oil wt difference
Originally posted by esham
Sorry guy an interupption... How much gap range of wt diff oil I should use between front diff and rear diff ?
A friend told me it should 3000 wt diff means if I put front diff 10K than the rear diff oil combination should 7K. Is that true?
What are the condition that I should consider to determine how much wt diff oil I should use for a track? And what are the effect on my cornering? Thanks
#6902
help with rody 5 port
hello guys i need some help bad:
i bought a rody modified 5 port turbo and while taking it appart to inspect it i found metal shavins inside the crankshaft and block,i then took the sleeve and piston off but i canont get the crankshaft off the main bearings,i tried pushing it but no luck,can i tap it with a hammer or should i heat up the the block and then try to push it out,i haven't done anything further for fear i might damage the crankshaft,also you guys think is worht to have these engine modified even more,i got acces to a couple of modifiers here in cali..
you guys thing the the metal shavings are enough reason to send the engine back to the manufacturer,
thank you guys for your help
also what pipe are you guys using on your rody's 5 port
thanks
thanks
#6903
Re: help with rody 5 port
thanks
thanks
#6904
crankshaft
thanks guys but the crankshaft STILL INSIDE THE ENGINE,it will spin ok but will not come off
#6905
Re: crankshaft
#6906
Originally posted by VoneRkid
Graeme when you paint you body use the paint masks fromhttp://www.rcxotic.com/ when you are ready to that give me or Jeremy ring.
Damo
Damo
Its not a bad little site for a bunch of guys doing it in their spare time.....
Check out the 2 latest reviews... you might reconise the body from brendale......
#6907
i read your mtx 3 article and its pretty kool!!
Jeremy
Jeremy
#6908
I must admit I've used masks of the rcxotic.com site a few times. They are of good quality, and if you print them on blank parma masking sheets they make painting your bodies a piece of cake.
Graeme
Graeme
#6909
Sparksy do you get you're RDlogics stuff in Australia or do you buy it direct. If you buy direct can you please tell me what there service is like as there a few things on their site I would like to get.
Graeme
Graeme
#6910
Graeme
Graeme
jeremy
#6911
so howz the car comming along there greame?? i just gotta re tweak mine then im ready to race!
any news on ya pipe? and what set up you running.
Jeremy.
Jeremy.
#6912
yeah I found contact to fiddly unless you buy the expensive nylex brand. Blank masks are that cheap for the amount of mask you get. Going to get some spares this weekend and maybe some alloy wheel hubs gotta wait and see what I can get my hands on. Hopeful I'll be running the engine in on Saturday at the moment it look like there's no working on Saturday ( you rippa ), so get fuel Friday night and run in Saturday.
Graeme
Graeme
#6913
car seems good just been setting it up over the past few nights. Double and triple checking everything to make sure it's all sweet. Not sure what set up I'll run first of all, the box set up seems a bit weird to me, like that huge rear ride height and the front toe out how aggressive do want the steering. But I suppose that my they are team driver and test pilots and I'm not.
Graeme
Graeme
#6914
hi
#6915
just get ya self a spare rear end part, etc turret comes with shock tower spare blade mounts, and turret fixtures, im gona reinforce my new one tomorrow!
jeremy
jeremy
