Kyosho VoneR Thread
#556
Originally posted by Mauler
Hey Manti...are the floating blocks suppose to be free to slode up and down the shaft or is it suppose to be tight on the case... Mine seems rather tight and it makes no sense at all! Made any modifications to ur casing?
Anyone too?
Anyone too?
#557
Regional Moderator
Anyone too?
Anyone too?
#558
Regional Moderator
No wonder... the Kyosho LSD is not very much different from the appearence other than the floating blocks... Don't quote me but I think the material used for the bevels could be inconel... other than that, given the density and price, I could not think of other materials that could withstand the wear!
By the way White Cat...you have the 1/5th site for reference?
What is inconel?
#559
Originally posted by White cat
You need to match the gears with floating blocks. My LSD is not tight at all.
#560
Regional Moderator
Originally posted by Manticore
#561
The tolorance of the gears and floating blocks is not 100% perfect. Some gears are tight in a particular floating block, but some are loose. If the gears and blocks are matched before installation, you will get a perfect LSD.
#562
Regional Moderator
so you need to buy extra unit for your master matching???
#563
I found the link from here: http://www.rev-up.co.uk/index1.html
What is inconel?
What is inconel?
#564
#565
Regional Moderator
Yeah...mine is loose too...as if I had no oil at all in the diff... but my question is whether the floating blocks are supposed to "float" up and down the bevels? If not, why are they not "fixed" blocks? Still doing my little experiments at home to understand the working... very very different from the Kawahara negative diff!
This is how the Kyosho LSD works. LSD is to control the different rev of both left and right wheels. It doesn't lock up when both wheels have similar rev. When both wheel have different rev and the difference is up to a certain point, the bevel gears move at high rpm and generate heat. The bevel gears expand and lock up with the floating blocks. In the mean time, the diff feels like having some heavy diff oil. When the bevel gears slow down, they become cool and the friction is gone. The black oil is used to control the temperate of the bevel gears from being too hot.
#566
I also don't know why the blocks are called floating blocks. Kyosho should have call them friction blocks or something similar. Those blocks never float!
#567
Hey, just tried out the LSD up front! I'm telling you guys out there to get this! Acts like a one way in corners and provides a powerful punch out of corners! Moreover it doesn't spin off like the one way! This baby is more than sweet!
But it rather pricey though....
#568
Regional Moderator
WC, dont make thing so complicated, think about it when you have a steel metal expend to a visible size, you probably melt down the diff case. the floating block's function is to lock with the small bevel gear when the bevel gears inside the diff has spin to a certain speed. i.e. it called floating block. the theory is the same as the oneway bearing.
Shoot! You mean I put a oneway in the rear??? Should I put it in the front or rear?
#569
Regional Moderator
#570
