Kyosho VoneR Thread
#3991
Originally posted by AMGRacer
I think in the US Tower hobbies has the Kyosho market sewn up.
#3992
would a jr xr-2 be an ok radio or would u guys highly recommend fm?
#3993
i can't comment on the jr as i've never used one, but make sure at least that it's got ;
-end point adj (throttle and steering)
-brake adjust
-steering speed
-things like throttle speed help if you aren't acustomed to the speed of your new motor and find it hard to go easy on the throttle
i think there might be a new xr2 comming out, or it's already been released, not sure.
#3994
thxs
my dad is buying me the radio so there is no point in saving up, seeing as how i dont get allowance, lol
anyhow, i was also thinking of gettuing an airtronics mx-3
thxs
thxs
#3995
hey, i got the mx-3 today,
i need help "tunning" it,
what percentage epa do u suggest on the throttle/open, and steering things, lol
i'm new to this radio and dont wanna mess it up
thxs
thxs
#3996
Re: Blue Star update
Originally posted by patelladragger
Well after my completely unscientific tests of the team blue star bearings I have to report they're nothing special really. I put some in my VoneR and I really think that properly maintained stock bearings are more free than these. I tested (among other tests) with the front one-way and axle bearings only and I found that the stock bearings which I had pulled one shield and degreased and lubed were MUCH more free rolling than the team blue star. Maintenance doing it this way is a pain but if you're accustomed to breaking your car down it's a noticeable improvement.
Will report on the weight of the kawahara chassis compared to the integy 7075 and the stock this weekend. I'm looking for ways to trim weight out of the car - any ideas?
#3997
are the K factory hop ups good for the VoneR and RR?
#3998
almost any hop up partsmaker is good, except for gpm, lol
hey, by the way, i broke one ogf my 45mm adj. sterring rods, lol
i went diagnanol into a curb at around 30mph, man was it ugly, my car went into a viscious spin
do u know how much the sterring rods are?
thxs
thxs
#3999
turnbuckles are steering rods, rite?
anyhow, will these "turnbuckles" fit on my v one rr?
1404 Blue Titanium Turnbuckles, 1.775”/45mm, they're factory team ones, or should i get the titanium ones that kyosho makes for the v one rr?
thxs
thxs
#4000
Chassis / Bearing Update
ok - spent a little time with the kyoshos today.
On the chassis, I found:
Kawahara 3.9oz
Stock 4.4 oz
Integy 7075 4.6 oz
Noticeable difference picking up the kawahara compared to the other two. The stock and the kawahara are pretty close to 3mm, the integy is closer to 3.2 -3.3 mm in many place.
on the bearings - after trying to take the shields off ALL the metal shield bearings in these cars (that weren't already off) I came across a few of the team blue star ones I was taking out that were pretty free. I started taking the rubber shields off them and found that most were packed with a very heavy grease but some weren't (the ones that were free). Basically after taking the shields off the blue stars and degreasing them with denatured alcohol and relubing with synthetic motor oil they are VERY good.
Also it's 10 TIMES easier getting the rubber shields off - so I think if you prep these blue star bearings they are the ticket. Especially at 26 bearings for 20 bucks.
Kawahara 3.9oz
Stock 4.4 oz
Integy 7075 4.6 oz
#4001
Patelladragger: Paying attention to the Kyosho is a good idea, Good info on the chassis weight, I have been eyeing one of those for some time
But doesnt the miss's get angry because you are spending time with another LADY
Kevin: wich hobby shop down your area cary K parts ?
I need a bigger gear selection to run those bigger tracks, and nobody has what I am looking for in my area.
My bags are packed and I just painted 2 bodies for this little trip
#4002
Patella: thanks for info on the bearings...
HAG: Try Elite hobbies in W. Covina, just a few minutes from where you'll be staying on Citrus Ave. My second choice is Pegasus hobbies in Montclair, not too far from Revelation. Call me when you get in town, if you need directions.
#4003
I will probably use up all my minutes calling you, going to be a long distant phone call, when I am in the area
#4004
Re: Re: Blue Star update
Yeah, nothing special, no more durability...inexpensive, but still disappointing regardless. I would trade the extra resistance for lasting longer and more reliabilty, but these seem to get eaten up as easily as the stockers.
My blue bearings were bought late last year some time (forget when) and they are still kicking. I have not shattered one of them and I have only cleaned them 2 times in the interim. Out of the original set only 4 have become gritty the others are perfect. But perhaps I just got a "lucky" batch.
BTW I pulled all the shields off them and cleaned them out before installing them. The shields are easy to get off and on. They are clearly smoother than the stock bearings after this treatment.
#4005
yeah AMG mostly what I already said - once you get that heavy grease out blue-star is great. I pull the shields off one side only and when re-installing put that side towards the inside.
I've seen guys do this even with off-road buggies. If you have a jewelry cleaner and compressed air the process is very quick once the shields is off - it's only that first time getting them off that is a bear (blue star is much easier though).
Just pop them out, spray the bearings out, throw them in the jewelry cleaner for about an hour ($15 at wal-mart), spray the bearings out dry when done, and finally throw them in a bowl of the lube of your choice. I got from the MRX3 site to use synthetic mobil oil. I did this with another car and could get about a month of super-free drive-train before I needed to relube. After getting the R back together for the first time last night with this treatment I must say the improvement is incredible! The bearings are even more free with one-shield off.
