Kyosho VoneR Thread
#3811
kawahara chassis weight
anyone have the kawahara chassis and by chance know what the weight is compared to the stock chassis?
#3812
Originally posted by AMGRacer
So the Hudy arbors fit the Q-World truer??? Might have to give it a try.
I promise to play nice if others do Mr Fok
Yes as already answered the Hudy arbors fit.
Alright play nice or I'll take all yall toys away. Mu
#3813
Originally posted by HEYALIGNMENTGUY
Hey who made sydewynder the keeper of the peace
I want to know is he ready for the LA trip
I'm not ready to go to LA. Been feeling sick. Think I have to go to the hospital.
#3814
Thanks for all the info on the tire truer. I'm most likely going to purchase the Ofna Automatic with Hudy Accessories. I think Stormer had the best price of $229 with only $6.95 for shipping.
BTW - AMG what type of jig saw blade are you using (Carbide?). I've heard the stock blade dulls easily.
#3815
#3816
I was using both these truers at a recent large meet and frankly I could not see a difference in the cut quality. My blade is the original one which came with it and it is still fine. HOWEVER I treat my stuff well and I only take 2-3mm skims off at a time. I cannot tell you how well it will go if you go hacking off big chunks in 1 go.
I also also heard the Hudy carbide cutter will work in the Ofna unit. I just wanted to make sure, because I don't want to spend the $32.00 for it if it doesn't work. I'll probably use the stock blade for a while, then switch to the Hudy one when I need to replace it.
#3817
I just power mine from a car battery. You need some serious amps if you start taking big bites of foam thats why I use the car battery.
Yeah try the stock blade and compare to the cuts from the Hudy item. I could not see much difference to be honest.
#3818
Does anybody happen to know the part number for the Kyosho wide bumper, and if it works with the standard foam and upper bumper piece for the standard V-ONE R? I've seen the Kawahara one and it looks pretty nice. Any suggestions between the two?
#3819
I think I'll just stick with my car battery. I was just curious if you can run 2 7.2volt batteries (like a starter box), and if they would last with that much amp draw. I don't want to order 2 more batteries if I can only true a couple of tires before they wear out.
#3820
#3821
That's what I heard also. I believe to use a AC-DC converter, you would need something capable to put out 20-30amps. I think integy sells one, but it's like $200 dollars.
#3822
Do you see the "All Rights Reserved" in the picture AMG? Do you know what that means?
10 minutes to cut 1 1/2 tires? I think I've seen HAG do it in like 2 minutes. Man you must work for the government.
#3823
#3824
Zac tyres GOOD, wheel not so good if you run a one-way, the run out of the wheel south after a day of practice.
I wish the wheel would stay true because I have a lot of tread left
#3825
Originally posted by Manticore
AMG is saying shopping at that shitty "online" shop is hazardous to your wallet !!
Well 500 yen is about 3.70USD or about 28HKD retail. Hmmm someone wanted to sell HAG that for 12USD.
