Mugen MTX-2
#1576
Re: Re: Gear set up
Originally posted by Ah10
This is a very hard to answer question! really depends on what kind of engine you are running, clutch set up and such!
Yes my engine is maxed out at the end of the straight! the track that I am running has a 200' straight plus a good 50' right sweeper before the straight so that would make it a total of 250' for the engine and gearing get up to the top speed!
by the way I am using RBX12T 5port engine, man this is a beast! it screams!
#1577
I have a roll out gear ratio calculator in excel. It will find the correct tire sizes. over drive, gearing etc. Email me and I will send it to you. It is in excel and dummied down so it will work with my palm pilot at trackside. [email protected]
#1578
KAWAHARA NEGATIVE DIFF!!!
Seen alot of posts on this ,What lube do i put in the diff gears, will asscociated? plum stuff do its for bevel gears??
needs to be available in the uk!!
#1579
Re: KAWAHARA NEGATIVE DIFF!!!
#1580
Originally posted by ketchup_gsr
thanks for the info, siokoy, about the neg diff. I still don't want to cough up 90+ dollars for it just yet. I got myself new tires, according to AH10's specs. 26 in the front and 32 in the rear. Fits fine on my prospec. hopefully this weekend it'll run better, with AH10's help.
I'm still kinda hesitant to run it at 240+. Should you do a compression test when the engine's dry or when it has some oil (after run oil)
Regarding the engine.... never test the compression when its dry it will damage your piston sleeve and thats a very expensive part of our engines. Try testing your compression with an after run oil inside your engine
#1581
#1582
Re: RE DIFF
Thanks Siokoy
What differance will i notice??
Thanks Siokoy
#1583
raffaelli
I would like a copy, I sent you my e-mail.
Cartman
I am using silicon grease Hi temp - hi speed I got from my LHS.
Cartman
#1584
Re: Re: Gear set up
#1585
Turnbuckles
Does anyone know which titanium turnbuckles (front and rear) will fit the MTX 2?
Could you also, please, tell me the size of the turnbuckles?
Thanks!!
Thanks!!
#1586
Re: Turnbuckles
Thanks!!
Thanks!!
For the rear turnbuckles I used the steel ones made for the Yokomo M2USA/M2 Type J. I did have to cut them down in length and also had to trim the ball ends a tad in order to get the correct size to fit the car. On the front I kept the stock parts. If you check some pages back, I posted a picture of the rear link. I would post it again, but I'm not at my home computer.
Rich
#1588
Thank you very much guys, but I need the titanium ones.
I am actually using the HPI racer I in the rear. I didn't need to cut anything. It fits perfectly, and I can adjust the camber since it has a hole in it. I'll post a picture when I get home this evening.
Last saturday I broke one of the front ones and i decided to replace for titanium in front and rear, for better looking too
I found that Lunsford makes them but I don't have the exact lenght to order them.
I'll keep you posted
#1589
Re: Re: Re: Gear set up
Originally posted by Novarossi
Running the Gray clutch shoes and lightweight flyweights will give you the acceleration your after
#1590
Chassis
I picked a Kawahara chassis today when I went to the LHS. This is a nice looking chassis Beveled around all the openings, sloted for the front belt and a cooling hole for the engine. I took some photo's
[IMG]c:\camcorderphoto's\chassis3.jpg[/IMG]
I have others also.
I have others also.
