Oversteering... why? How to control that
#31
Originally posted by Cartman
just adjust your droop on the rear TRUST ME!!!!
#32
Anti Roll bar and Tires
Hello Everbody, yesterday somebody in this thread lead me to www.mytsn.com and something interest me is about anti-roll bar function. I not really firm what exactly this thing can do so I read it ... so I check my car it is more that 45° ! And I notice there is a allen screw which is to hold the anti roll effect was loose and not in function position so I tighten the screw, adjust the anti roll bar angle to 0° and....and....and... change the rear tire to form tire 37 Ellegi ! ( Which it is in my tool box so I just change it to see if there is an effect )..Surprice ..NO OVERSTEER !!!! Full speed and corner...NO OVERSTEER! Woww.....
Now... I do to many changes at one time I not really sure which is which now.. is it due to the anti-roll bar? Or the stopper screw at the antiroll bar or because of the tire! I did not test to change back the form tire to my rubber tire back again because so happy until forget about that ... I will test it this noon...
#33
I'd say it was the tires that made the difference.
I was at a big race, not too long ago, where the Factory Team Serpent was there. They gave a handling school, and said that set the car up straight and true, then fine tune the car with the tires.
#34
should read: " they said, to set the car up..."
#35
Re: Anti Roll bar and Tires
If your front sway bar blades were not initially linked properly (same as the front sway bar not installed), then I say that the reason why your car performed well was due more to the front sway bar. Just my opinion... But I agree with theRed5 that tires are everything.
Were you using rubber tires before changing to Ellegi 37 shore foams? What is the front tires?
During this test, were you using one way front?
#36
Yes..theRED5 probably is the tire but I still need to do more test with changing back the rubber tire that I have problem with. Than we so to say confirm the root cause of the problem.
InitialID, I just change the rear to Ellegi 37 shore foams?. The front tire still remain the same as ore (Rubber tire Sorex 40R ). So Front is rubber, rear is foams.
#37
And... I 'm using front diff.
Just now during my lunch time I manage to reassembly my front one way back again and install one way spur gear at 2 spur gear changer. Going to test it today after work if its not rain!
BTW what exactly one way spur gear function? Is it will improve the performance of my car ? Actually I do have that option part sometime ago but did not have much time to assembly it.
Option part I bought it but without really know the function is. So anybody know about that part?
#38
That servo tape thing, is that under or over the insert? Either way, with rubber tires I would advise against it. That air gap, that the servo tape was taking away, succesfully decreases traction. A larger air gap generally means more traction (unless of course the air gap is causing your tire's sidewall to collapse in a corner, but there would be a crease in the carcass to tell you of this phenomena).
I thought you were running in a rubber tire class? If you aren't, I would go with all foams all around.
Personally, I think something is messed up with your setup if you have more traction on the front end with 40R's compared to 36R's in the rear. With foams of a durometer of 37, you should have an unbelievable amount of push, and so I don't think things are quite settled in the setup department.
#39
never never run rubber front and foam rear. allway 4 X foam or 4X rubber
#40
A one way allows the car to roll into the corner, not scrub speed off like 2 diffs will do. With a one way, the car will not slow down as much...Use it if the track has fast turns, not tight turns.
#41
esham's next question will be about BRAKING using the front one way....
#44
Finally no oversteer with rubber tires
Hello guys, finally I change back my rear tire with new tire. This time I didn't apply double side tape at the center of the rim and I use Sorex tire 36R with soft insert. The adjustment was
1. The tire - from double side taped rear rim to none.
2. Adjust the antiroll bar stopper from big gap to tight gap -reduce the damping ability.
3. Rear drop
So my conclusion I believe is due to the tire and the anti roll bar screw. The rest are more standard setup, harder spring in front, softer at the rear etc. Thanks everyone
3. Rear drop
#45
What I learned from this thread
And thanks to everyone that take part in this thread. What i learned from this thread is :-
1. Spring function
2. Anti Roll bar
3. Rear drop
4. tire
5. caster
6. Diff
That interesting isn't it!
1. Spring function
2. Anti Roll bar
3. Rear drop
4. tire
5. caster
6. Diff
