Like Tree18Likes
Xray NT1
Old 06-03-2007, 10:51 AM
  #1126
asw7576's Avatar
Originally Posted by itchy b
Hey Chris, are you saying that you feel like me which makes you want to build one?
Don't be putting the blame on me for that!!!
LOL...... my hands are so free now !!!!
It's beautiful car isn't she ? itchy.... itchy..... ithcy...... scratch... scratch.... scratch
asw7576 is offline
Old 06-03-2007, 06:29 PM
  #1127
all i can say about the NT1 is that it is simply awesome. i bought the combo kit were you get the car engine and pipe. i havent raced nitro since i was a novice which was 6 years ago. i raced the NT1 for the first time with no practice this weekend, i went to the race with a car that i just broke in an engine in and had never driven on a track. after round 4 i qualified 8th in the A. this car is so easy to drive and work on i love it. i broke 0 parts all weekend. i cannot say enough good things about this car other than good job xray.
goop is offline
Old 06-03-2007, 06:33 PM
  #1128
Nexus Racing's Avatar
Originally Posted by _cyclops_
0.6mm sometimes 0.5 just to make the car easy..
Cool, I tried the yellow shoe with a 0.55mm gap today and it was a pretty dialed clutch setup .
Nexus Racing is offline
Old 06-03-2007, 08:58 PM
  #1129
The previous post from boy2rc shows him running the s9451 as a throttle and brake servo...I thought that this servo was for steering...Correct me if I'm wrong....Can it be used for either???
DaNNy671 is offline
Old 06-03-2007, 09:37 PM
  #1130
boy2rc's Avatar
My other car RRR using s9451 x2 it run almost two years, no problem.
boy2rc is offline
Old 06-03-2007, 11:31 PM
  #1131
Yah, in the beginning i always had a gap of 0.7 but it seems the clutch is easier with a smaller gap, which results in a easier car which results in beter driving (in my case :P)
_cyclops_ is offline
Old 06-04-2007, 06:36 AM
  #1132
Cool
DaNNy671 is offline
Old 06-04-2007, 08:29 AM
  #1133
i have not had a problem with my thrust bearing and im at about 1 gallon of fuel through the car.
another racer brought out his new nt1 for the first time and the thrust bearings broke in half after his second tank of fuel.
he took the grooved thrust bearing plates and reversed the and put a third thrust plate between them . basically three thrust bearing plates greased them up and it worked awesome .
i dont think that set up will ever fail as there is no bearing.
when my thrust bearing fails i am going to go this route also
i know it sounds crazy but it works very good and is bulletproof
cheers
Nitrogasm is offline
Old 06-04-2007, 08:31 AM
  #1134
mtveten's Avatar
Trader Rating: 29 (100%+)
Originally Posted by jelayne
Mark can you share the part number for the Kfactory trust bearing ?? thanks
The k-factory 5x10mm thrust (G4S part) p/n is 150510T. They sell for about $10 @ racedayhobbies.com hold up extremely well.
Mark
mtveten is offline
Old 06-04-2007, 09:41 AM
  #1135
royfan33's Avatar
I've almost got my NT1 completed. I'm getting ready to build the shocks and wonder if you guys have any suggestions on pistons, oil, and springs for typical US parking lot racing.
Our track is pretty decent with 100-120ft straight, nice newer blacktop, sprayed with sugar water. With my G4S I've been running 1.2/30wt, and med-soft springs(pink/purple TM)
And on the pistons any reason I shouldn't use the adjustable pistons?
Gary
royfan33 is offline
Old 06-04-2007, 10:28 AM
  #1136
mtveten's Avatar
Gary
The adjustable pistons just give you the ability to make minor adjustments in your dampening without having to rebuild the shock. I would recommend using them since it makes the piston adjustment easier with no downside.
As for a starting setup I was previously running a G4s with the same spring setup & 40wt/ 1.2mm 2 hole pistons locally and am using 25/20lb springs w/ 60wt oil & 2 hole fr & 3 hole re pistons.
Mark
mtveten is offline
Old 06-04-2007, 10:37 AM
  #1137
royfan33's Avatar
Mark
Thanks Mark. Can't wait to get this thiing on the track....
royfan33 is offline
Old 06-04-2007, 11:42 AM
  #1138
Sal Amato's Avatar
Trader Rating: 27 (100%+)
For those of you just now building your car I would suggest yo add the stk thrust bearing to the Junk pile, its only good for about 1 gallon when regressed every hour. The good news is the k-factory thrust bearing is a drop in replacement and should last a full season or more even if neglected.
For those counting the required upgrades now include the yellow show, front CVDs, after market thrust bearing, and possibly the multidiff.
Mark
is there a part fo r this thrust bearing?
Sal Amato is offline
Old 06-04-2007, 12:13 PM
  #1139
mtveten's Avatar
Mark
You can also use a serpent centax 2 or 3 thrust bearing.
Mark
mtveten is offline
Old 06-04-2007, 01:08 PM
  #1140
Mark how good are the ones from Serpent compared to kfactory?
jelayne is offline
