Mugen MRX-4R
#346
Originally Posted by quietstorm76
I'm going to try the Dome body or the MSR Whip.
Go with long wheelbase and maybe reduce the caster to see if you get better steering. What rear upper arm position you're using? Long, Middle, Short?
#347
Originally Posted by Corse-R
I definitely would go for the Dome body. Maybe you would try with the red rear springs to see if things got better to you with them.
#349
#352
Originally Posted by MugenDrew
Turn in off power, on power or while braking? Rear sway bar is at 3mm? You may simply want to lay the front shocks down.
Btw the problem is at corner entry.
#353
Thanks, I'm running the blade type sway so I'll try on a stiffer setting. I also just put the pink springs on the rear also to see if that helps. Which is stiffer the pinks or the reds?
The Pinks are stiffer than the Reds.
What steering ackerman are you using on the car?
#355
Any suggestion how to make my MRX4-R to rotate ( carry corner speed ) faster ?
I find my car is slow at medium and low speed corners.
I'm using 5.5 rear susp. block and A steering ackerman with all white springs.
#356
I'm using ackerman A and 5.5 rear blocks.
Depending on the track / layout you run at, if D or A Ackerman is extreme as I described above, use the B or C ackerman to find your sweet spot.
There are few other things you can do to gain steering from the car...
- What Shock Oil do you have right now?
- Do you have the new Rear Floating Body Mount on the car?
- Front body mount?
Its good to see you're planning to try the new MSR Whip because you will gain steering with this body, yet maintaining overall stability.
Note: you will need to use the long Front Body post for the MSR Whip.
#357
Quite amazing to hear you have not enough steering on an MRX-4R compared to the rest of the cars mentioned. Where we're at the MRX-4r have the most steering, almost to a point of oversteer.
If the advise you get here is still not enough steering for you.... i think you should check your controller EPA!
#359
- Front body mount?
