Mugen MRX-4R
#196
Originally Posted by sohlman
I see u on this thread, C-Whit. My R is comin for ya.
#197
Originally Posted by captian
are serpents welcome
#198
Originally Posted by THE DOCTOR
Just starting to put my 4-R together, where should I start out on the belt tensioner, front, mid, or rear slot?
When belts are worn, switch to the rubber ones (at least on the center and rear), the front, some people use the rubber, but found that urethane gives me more durability and less chances of needing to change a front belt (with the added hassle is to rush a belt change on the pits).
#199
Originally Posted by Corse-R
Yep... never is too late for switching to a better car.
#201
By all means please come
#202
#203
Hate to do it, this car is awesome, but it will never get used
http://www.rctech.net/forum/showthread.php?t=126733
#204
UPDATE!
Mugen MRX4R 1/8th On-Road screw kits are now in stock!
Mugen MRX4R 1/8th On-Road 232-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws.
Kits will begin shipping today, August 24th, 2006.
Thanks and best regards,
#205
Just bought MRX4R finally......
I bought used MRX3 earlier and I don't feel happy with it.
#207
Thanks.
I'm building the shocks right now....
It will be ready for racing next month.
#208
#209
Which engine will you use at last for your new ride?
Anyway, racing with buggy engine was terrible at low speed corners and straight. The low end acceleration was slow but the top speed was fine.
For my new ride I settled with Novarossi 35 plus 21. I couldn't be happier
As for my Hyper8, I have to buy another WS7-3 again.
#210
Hahaha...... you know that I was using buggy engine ( RB WS7-3 ) for my first ride ( used mrx3 ). The engine is dead now. One of the engine mounting is rip out and I can see the crankshaft It happened during final, the car flew and landed on asphalt with the head on. Bamm !!! that's it !! ......bye bye a brand new engine.
I've been playing with the clutchbells just to balance them for a given pinion cluster (on the past weekends saw 3 .21's blowing the crankshaft end due to unbalanced clutcbells) and scared a little.
Got access to harmonic balancer and what was my surprise to see that all the clutchbells were severely imbalanced (the small hole to adjust the clutch is the main culprit). Balanced a pair of them and looks like this (don't take into account that used some old clutchbells for the test, looks bad but theorically are way better than new):
