Serpent 720
#991
Originally Posted by rccobra705
You can also use Kawahara centershaft set part # ZF-142 and you need 2 sets, because this set have a long and a short dogbone. I use the long once at my 710. Never lost one and don't use fueltube or other things between.
#993
Originally Posted by DS Motorsport
I run 30.000 in the rear diff and the car is very stable in the canteen.
Didn't had any problems in the canteen, full throttle is no problemo.
I mean if you lighten your rear diff too much(10.000cst) make sure you don't have fast corners(70+) at your track, otherwise you loose all stability.
#994
Originally Posted by serpentpro28
Anybody know where i can get parts for 720,most especially the rear shock tower
#995
So is there a transponser mount and holder set for the 720 ? I don't think the one for 960 fits. I could buy the transponder holder, #1666 but don't want to drill two additional holes on the upper deck. If I mount the transponder on the front then I do need the extention.
#997
Originally Posted by Team Kamikaze
#1666 comes with the front servo mount which has 2 special holes for the transponder mount, go to my TSN and take a look, who says you need to drill holes? by the way the #1666 just came in (it is now in stock in the store)
#998
#1000
It went on the car perfectly for me WITHOUT modification
#1001
http://www.mytsn.com/products/product.asp?prid=4298
#1002
#1003
Originally Posted by aaalp
Why bother with an additional transponder mount if you can install the transponder on the noseplate 803146? I don't get it.
#1004
Originally Posted by Julius
t might be usefull for racers that use handout transponders.
#1005
Originally Posted by Acid
Hi Guys
I took the 720 for its first competition run and the car is good but had the follwoing problems.
1. The rear of the car is loose - allot of the 720 drivers experienced the same problem - track only has hairpin bends - everyone said the same thing, the back doesn't follow the front. But still the car was easier to drive then the 710.
2. The rear lower wishbone - with two pivot balls is very weak - if you toutch the rear side of the car against the track piping - it pushes the rear pivot balls further in - I started with 3 toe in at rear and the slightest toutch at the rear and I was running 3 toe out. I wanted to try thread tape over the pivot balls but i did not get a chance too.
But, just so that all of you know, the winner at the Soth African Nationals in Durban this weekend was a Serpent 720.
Really not sure why the back of this car is so loose.... any ideas? I figure its the diff oils - the standard 50000 F and 30000 R doesn't work on a hairpin track. Thinking more like 100000 in the front and 10000 or 20000 in the rear.
Acid
Acid
I agree with your idea to run harder front and softer rear oil. I'd suggest about 80k front (100k might take away too much steering) and 20k rear. Running front and rear shocks in the lowest tower holes will improve handling as well.
