Serpent 720
#1486
Thanks for the rear diff infor
Originally Posted by Jo Gutierrez
Attached is what the reference guide calls for to have ball diffs. The stock gear diffs are 35T front and 47T rear. The ball diffs of the 710 are 35t front and 45T rear.
Cyclops is right, just change the rear to a 47T (part#808376) and it should be fine.
PS
Jo Gutierrez thanks alot on the rear `Diffs
#1487
Originally Posted by madbeats
Guys am just putting the last few bits on my 720.. just waiting on some skyline parts and its done i will test and give a full report all the hop up ...
PS
PS
Let us know how your test goes .
#1488
#1489
front belt rubbing
anybody have problem with front belt rubbing at the servo saver turnbuckle,btw im using jr8800 servo for steering?
#1490
#1491
give it a try and compare.....
#1492
Originally Posted by ghoppa
go back and change your servo arm to the "stock arm", it looks like the aluminum arm you are running is too "tall" and placing the ball end too close to the center of the car causing the rubbing...
#1493
Double check the eccentric bearing holder. There's a left and right position to it. If this still doesn't solve the issue, you may just shave a little bit of plastic off using a Xacto knife. You don't have to take too much, as the picture shows very small wear from the belt .
Thanks Joe
#1494
Thanks'
#1496
I did check the bearing holder and it is good,i just found out that the jr servo is taller than futaba servo coz' one of my buddy doesnt have such problem on futaba for steering.
Thanks Joe
Thanks Joe
#1497
Originally Posted by buboy28
i'm using futaba 9451 servo for steering but does not have the problem you have, does jr have low profile servos might be able to solve your problem
Thanks'
#1498
I use the ko servos and have no problems.
#1499
All high speed servo from jr have the same size,i might need to swap my servo steering and get a futaba or ko propo' any feedback with the new ko servo?
Thanks'
Thanks'
My bro has one of the newer KO's available. I think it's the 2365?? but I'm not sure about the number. Anyways, he likes it a lot as well.
#1500
Hi guys:
which one is lighter? 802163 802162? aluminium middle shaft or the new SSP middle shaft?
Regards
Eduardo
Regards
Eduardo
